Home > Td5 > Drive Belt Replacement |
Is there any numbers on the old belt
if so using new belt numbers as example it is 7pk so 7 grooves wide , 1715mm long or order one bit shorter/longer so just knock off or add on what you think you need normally one a few mill either way will still fit |
17th Feb 2015 7:46pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
Thanks munch! unfortunately there is no markings remaining on the old belt but that may be because they were eaten when the tensioner failed and it minced it all up
I will measure what remains of the old belt and see if I can get an idea on real length. Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
17th Feb 2015 8:01pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Buy a genuine belt, the're not expensive.
I've seen some pretty poor pattern part belts - not worth it. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
17th Feb 2015 8:26pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
You could consider a genuine one from the dealer (approx. £27) all you need to do is give them your reg / make / model.
Probably need two of you to fit it and easier if the viscous fan is off |
17th Feb 2015 8:30pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
You need a 7PK1800: http://www.advancedfactors.co.uk/7pk1800-a...6393-p.asp 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Feb 2015 8:41pm |
Thanks Martin et all... I will do a few measurements now on what is left of the old belt and see what I can get hold of tomorrow. Defender 90 TD5 County -
17th Feb 2015 9:09pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
Sounds like you just have a non addition belt supplied. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
18th Feb 2015 7:04am |
Right thanks all the correct size is indeed 7PK1801 with thanks to my local friendly garage for a quick supply... fits like a glove and easy enough to do solo when using a flexi head ratchet to push back on the tensioner!
I ordered an extra through advanced factors to add to the toolbox.. cheers martin! Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
18th Feb 2015 6:00pm |
Great stuff 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Feb 2015 6:24pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
I know this is a very old post, but I'd rather revive than go new.
Could someone confirm for me that this: https://www.advancedfactors.co.uk/pqs10150...1221-p.asp Is the correct auxiliary drive belt I'll need for my 2003 Td5 XS with aircon? Defender 90 XS TD5 (03 Reg) |
16th Aug 2021 5:17pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Yes. Thats correct ðŸ‘ðŸ»
16th Aug 2021 9:43pm |
Ta Andy,
I thought it might be you that would confirm it Defender 90 XS TD5 (03 Reg) |
17th Aug 2021 1:05pm |
