Home > Technical > Does diesel glow under UV? |
Difficult to determine as most leak detector kits include dye. Is there any way you can syphon some out of the tank or bleed some off and try it on it's own perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
17th Feb 2015 5:44pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
good plan will give that a go and report back
17th Feb 2015 6:13pm |
well diesel seems to glow yellow/green under UV
17th Feb 2015 6:23pm |
