Home > Technical > Dash Clock
Grenadier
Dash Clock
Is the dash clock meant to be back-lit on a 2011 Puma or is that way too 'Avant garde'? Same question for the Hazard switch.
Neither of mine light up and I was wondering if they were meant to and have the same (now blown/broken) fuse or electrical feed?
I know I pretended to have X-Ray and Night Vision whilst in the Army, but this is taking the p**s.
Thanks in advance for any help. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #399706 17th Feb 2015 5:43pm
landy andy
They should light up when the lights are on.
Andy
Post #399801 17th Feb 2015 8:11pm
ericvv
Post #399808 17th Feb 2015 8:19pm
Martin
Site Admin
That's a LR part, not specific to Rimmer Bros - STC1205
But in answer to the original question, yes both the clock and the hazard switch should backlight. The triangle is backlit red on the switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #399825 17th Feb 2015 8:57pm
Grenadier
Brilliant, thank you all. Seems a surprisingly common fault. And thank you Eric for the previous thread, now I know how to get to the switch to check. Bow down Monsieur Le Grenadier
Post #399848 17th Feb 2015 9:37pm
Rallyevo3
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi, I've got a 2013 puma and the clock doesn't light up, I pulled the dash and all I could see was one plug going into the back of the clock but no bulb, where is it?
Ian
Post #874376 23rd Dec 2020 4:17pm
llessur
Undo the four torx screws holding it in and without the holder you will see where the bulb holder is
Post #874378 23rd Dec 2020 4:26pm
Rallyevo3
Many thanks Thumbs Up
Post #874379 23rd Dec 2020 4:28pm
There is an LED for this now you can fit off eBay to fit in.
I have one, but annoyingly I replaced with a regular one before it was avilable.
So for now I keep it on the shelf until such a time I may take the dash out. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #874389 23rd Dec 2020 5:12pm
gcc130
When I replaced the bulb in my clock I cut the corner off the holder so next time I need to change the bulb it will be easier๐Ÿ˜Š
Post #874391 23rd Dec 2020 5:17pm
Rallyevo3
Is it the green led one for a fiver?
Post #874392 23rd Dec 2020 5:21pm
Yes, on eBay. Cannโ€™t comment on how good it is but I have one to try one day. KEEP CALM AND Drill ON
Post #874395 23rd Dec 2020 5:36pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I brought the led one, when I tried to fit it it would not stay in like the origional one and did not make good contact so I reverted back Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #874403 23rd Dec 2020 6:14pm
