Home > My Defender > 130 DCHCPU conversion to 5 door its started |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Loving the paint job Andrew
That's one seriously big Defender!! Andy |
3rd Sep 2010 8:13am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
This is the water bladder that sits inside the tank, the rough position of the tank is outlined in red. The bladder was tailor made to suit the dims of the tank and the material the bladder is made from is Potable Water Approved. Click image to enlarge 130's have feeling's as well you know |
5th Sep 2010 9:51pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Very nice mate You cannot teach stupid people to do clever things
5th Sep 2010 10:31pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
[s]Sonic[/s] AndrewS why you choose to use a bladder instead of a rigid tank made of plastic or inox? Matteo
Defender 110 Td4 SE MY 09 Last edited by Bomber82 on 6th Sep 2010 6:32am. Edited 1 time in total |
6th Sep 2010 5:17am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Think you'll find Its Andrew who has a bladder Sonics just a Turncoat
6th Sep 2010 5:46am |
Ops.... Matteo
Defender 110 Td4 SE MY 09 |
6th Sep 2010 6:28am |
Sonic he is the shorter one The plastic 'hard' tanks are not available in the size or shape I required. Above the wheel arch on a HiCap Pick up is not as wide as a standard arch in the little Defenders So the tank was constructed using the available space and I made the bladder to suit. 130's have feeling's as well you know |
6th Sep 2010 6:53am |
Sorry for mistake, we know that you're more talented!!
How the bladder works? has a breather or is sealed, compressing while going empty? Matteo Defender 110 Td4 SE MY 09 |
6th Sep 2010 7:02am |
The bladder is fixed at the top using the eyelets 5 each side and it hangs inside the tank structure. The bladder is slightly larger than the tank structure.
Tha bladder has a 50mm Ø fill a 25mm Ø breather and a 25mm Ø outlet at the base. 130's have feeling's as well you know |
6th Sep 2010 9:39am |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
andrew's is it possable to commishion a blader with one off dims, i'm thinking about a wedge shaped box behind my second row of seats using that dead space with a high fill hose at one side of the vehical and a low tap hose on the other side ? if so ideas on will it work and a rough cost,
cheers mark |
6th Sep 2010 10:05am |
Mark
The bladders are made bespoke to peoples requirements. Do a sketch with your requirements along with the size of the connections you require and I will price it up for you 130's have feeling's as well you know |
6th Sep 2010 12:32pm |
