Home > Wheels & Tyres > 285 65 18 tyres - air Pressure |
roddy Member Since: 18 Jan 2014 Location: cheshire Posts: 32 |
What air pressure is recommended for 285 65 18 tyres?
9th Feb 2015 6:41pm |
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 |
I'm on 30psi front 40psi rear...
9th Feb 2015 7:12pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2642 |
I'm using 32 front 34 rear
9th Feb 2015 7:24pm |
I run mine as a daily - mixture of country lane and motorway. I have been running 32 f and 40 r. Also running with Twisted progressive suspension. Going away next week so need to give it a quick check over and realised that didn't actually know what air pressure the tyres needed.
10th Feb 2015 7:20am |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
40 all round for me.
10th Feb 2015 7:49am |
Was hoping that there would be a common answer. I will try different pressures.
Thanks for replies |
11th Feb 2015 6:25pm |
consumerize Member Since: 27 May 2014 Location: Berkshire Posts: 121 |
I guess the problem you have is all the different setups and uses people have. Mine is a 90 CSW, but I have removed all the rear seats, carry no load and typically only me in it.
Harder tyre pressures make for a bumpy ride, hence 30/30 for me. When I do load up the rear, usually with logs, it's a very different ride, actually feels better, but my arches are then almost at tyre level. Find your typical loading, pump the tyres up to 40 all round, then keep letting air out every couple of miles til it feels right might be a good experiment |
11th Feb 2015 6:39pm |
