Home > Puma (Tdci) > 2010 110 Axle/Tbox/Gbox oils again - sorry!
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Hi all, I've read so many posts and had recommendations from Opie, Castrol etc. that I'm now stuck in a loop and confused.
Can anyone see an issue with running CASTROL SYNTRAX UNIVERSAL PLUS 75W-90 (meets both GL4 and GL5 spec) in the Axles, Transfer Box and Gearbox?
Or do you think I'd be better with the following which Opie recommended:
Axles: CASTROL AXLE EPX 80W-90 GEAR OIL
Tbox: CASTROL AXLE EPX 80W-90 GEAR OIL
Gbox: CASTROL SYNTRANS MULTIVEHICLE 75W-90 FULLY SYNTHETIC MTF
Engine oil I'm OK with thankfully! Thumbs Up
Many thanks and sorry for dragging this up yet again! Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #397640 10th Feb 2015 2:51pm
MK
It is ok as long you do not use GL-5 rated oil in your gearbox. Tbox runs with either GL-4 and GL-5. Puma 110" SW
Post #397814 11th Feb 2015 7:57am
ozzie1989
Great stuff, thanks Smile Now: 2010 2.4 TDCi 110 Utility Wagon
Post #398125 12th Feb 2015 1:09pm
