Home > Td5 > TD5 home service |
I'll just give you the best tip, I'm sure many will benefit....
When you remove the main oil filter, loosen it off, then put a plastic bag around it (the filter in the bag) and unscrew it, the oil/filter etc will stay in the bag and not drop everywhere.... You'll learn to juggle the filter out around the turbo oil pipe withe experience |
8th Feb 2015 8:14pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Hi
First thing parts, there is a Europarts in Abingdon just off A34 Give them your reg no and they will supply you with everything you need! Don't skimp get every filter, including the spinner, they will also supply you the correct grade oil too. 2 filters on engine, one centrufuge, one canister, fuel filter, air filter, Do the axles, gearbox, transfer box, simple drain and refill. Get a decent container to catch it all in, and a 25 ltr drum to store it in Grease prop shafts, and ujs, check wheel bearings etc, wheels off, look at brakes, check discs, pads etc Check all fluids, check for leaks, oil leaks etc, lights all working......? It's all quite straight forward, I'm sure you will be fine 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
8th Feb 2015 8:19pm |
If you get your bits from eurocar parts get premium filters, they do cheaper stuff but dont bother
careful how tight you do the top bolts up on the spinner filter housing , they only as small thread in alloy housing and strip easily |
8th Feb 2015 8:26pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Make the best of having your friend there and do as much as you can get done. Grease all grease nipples change brake fluid if you can and maybe change coolant if it's not been done in the last 5 years.
I always use genuine filters and last time I did mine I bought the filters from the main dealer but was a boxed set of genuine filters but not in Land Rover boxes,Mahler, Coopers, etc. When you change the diesel filter be sure to fill the new filter with diesel before you fit it this will save you having to go through the purge procedure to remove air from the system If you do need to purge the fuel system it should be in your handbook but basically you depress the gas pedal 5 (or is it 6) times in quick succession and this will tell the ECU to run this procedure, MIL light will come on while it does this and go off when finished. Let us know how you get on. 2005 Td5 90 XS Steve Last edited by Lou Sparts on 8th Feb 2015 9:14pm. Edited 1 time in total |
8th Feb 2015 8:32pm |
Canister filter next to turbo can be a bit of a easier if you have a filter remover or incredibly small hands!!! 80" 80" 86" 88" 90"
8th Feb 2015 8:33pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5862 |
Or order a service kit from Defenderbits.co.uk and oils from Opie oils 1999 Defender TD5 110
8th Feb 2015 8:51pm |
If you struggle with the canister filter wrap it with a sheet of wet and dry or sandpaper with the abrasive side inside this will enable you to grip it. 2005 Td5 90 XS
Steve |
8th Feb 2015 9:58pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Land Rover have an A B C service guide sheet. I will dig a past one out and upload a pic. At the milage and age then your defender will require the larger B service.
I'll do it when I get back from work tonight. 2002 110 td5 |
9th Feb 2015 7:26am |
Click image to enlarge 2002 110 td5 |
9th Feb 2015 7:36am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Don't forget to drain the agglomerator if you don't know that is the small water separator just in front of the R/R/H wheel station.
9th Feb 2015 7:48am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
You can find the above sheet on several sites on the internet.
The agglomerator is that not the same thing as were the fuel filter is in? so it will be drained while changing the filter. Nice that you are going to do it yourselves, it is very rewarding. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
9th Feb 2015 12:51pm |
Yes sorry my mistake, I should of said sedimentor.
Note to self go to sleep earlier and retread posts before posting. |
9th Feb 2015 1:39pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Couldn't replace the oil filter on mine without unbolting the oil return pipe,got the old one off as it was a pattern part that was slightly shorter than the new OEM filter. Pov.spec,ftw. 2006, 110,TD5. |
9th Feb 2015 3:33pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
9th Feb 2015 3:47pm |
