Home > Tdi > R380 Gearbox Advice Please
StephenO
Ok, so gearbox has been noisy for a while, mainly in 5th under load. Time to do something about it.
I currently have a suffix J on my Defender 90 300tdi. The question is do I upgrade to suffix L and spend the extra £100 or stick with like for like. Defender is used a lot off-road but not uprated in any way.
Spoke to Ashcroft today, girl offered me to take the option of Input Gear & Bearings as well, she did say these would be refundable if not required. Clutch will be done and I'll proably get the transfer box serviced when it's off.
Obviously Ashcroft have a great name and most likely who I will go with but just thought I'd call on experience before I break the bank.
So who's done this mod, any advice welcome Thumbs Up 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #393812 29th Jan 2015 9:02pm
ibexman
If your going to do it , do it once upgrade parts AShcroft all day
Post #393841 29th Jan 2015 9:31pm
StephenO
Yep, happy to upgrade to suffix L as I believe it has a stronger main shaft? Not sure i need the rear HD support bearing or the 5th gear ratio upgrade. As I say it's not tuned in any way and I don't tow, happy to consider it though.
The question would be, do I need the suffix L box and the HD support bearing....not sure? Don't have any knowledge of this stuff?
Post #393854 29th Jan 2015 9:53pm
ibexman
Speak to Dave at Ashcroft
Post #393857 29th Jan 2015 9:54pm
ashtrans
Site Sponsor
Hi,
PM me your number, will call you tomorrow to discuss,
Dave Ashcroft Dave
Post #396263 5th Feb 2015 10:48pm
StephenO
Thanks Dave, will do. Thumbs Up 2007 Defender Puma Tonga Green
Post #396274 5th Feb 2015 11:07pm
excossack
I think my g/box failure was caused by the 5th gear bearing, so when I did mine, I opted for the bearing upgrade. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #396331 6th Feb 2015 9:13am
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Hi, what did you decide to go for? I need to make a decision on mine.
Post #396380 6th Feb 2015 12:35pm
StephenO
Having spoken to Dave today I'll be going for like for like gearbox Suffix J and input gear/bearings. No requirement for upgraded HD bearing based on what I use it for.
Starting the strip out this weekend. Issue with 5th gear but new one should be good for 80/90k miles so good for me. Thumbs Up
Thanks also to Dave for your advice. Thumbs Up Thumbs Up 2007 Defender Puma Tonga Green
Post #396453 6th Feb 2015 5:54pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I would hope it will last more than that! 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #396615 7th Feb 2015 9:51am
StephenO
5th gear bearing Dave not the gearbox itself. Not sure when mine actually failed but the Defender had 102k on it when I bought it so sounds about right.
Only time will tell but I'm only covering upto 3k a year on mine so should last a while. 2007 Defender Puma Tonga Green
Post #396622 7th Feb 2015 10:20am
