Home > Maintenance & Modifications > Sticky wheel cylinders.
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Having not used my other landy since 2011, the wheel cylinders are seizing up. I've stripped and cleaned the insides up, is it ok to lube everything with red rubber grease? (the propper stuff you get with rebuild kits) i.e. the bore the rubbers and pistons slide in?
some people say just use brake fluid but that doesnt stop the rust setting in. 1953 80"
1987 mini city e
2011 90"
Post #395975 4th Feb 2015 10:37pm
munch90
I would use a small amount of rubber grease , brake fluid absorbs water
Post #396023 5th Feb 2015 8:20am
