Home > Technical > does it apply to defender 90 -2009 puma
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hello I am getting a diagnostic : P167 - my vehicle is Def 90 - 2009
P167B- Fuel Injector Learning Not Done
Neutral
I have searched for details and found the following:
"you have done Q068 but dealer do not done injectors learning (same months ago LR system given errors on this procedure)"
Are there some Landrover fault diagnostics that should be removed from ECU ?
Post #395648 4th Feb 2015 8:21am
P167B is the DTC generated when the ECU believes for some reason that it has no calibration data (or incorrect calibration data) for the injectors, however unfortunately no-one outside of Landrover (or more likely Ford) actually knows what causes the ECU to come to this conclusion.
If the engine seems to be running OK and it is only the presence of the DTC which has alerted you to this, then I suggest clearing the fault and seeing if it comes back - it may well not come back.
If the engine is running rough and you have reason to believe that there genuinely is something wrong, then carry out an injector relearn (AKA pilot jet correction) cycle with a diagnostic system. This will cause the ECU to relearn the characteristics of the individual injectors. In extreme cases it may be necessary to re-enter the hexadecimal calibration codes whcih are stamped on the injectors themselves, though this is unusual unless you've cvhanged either the ECU or the injectors.
The P167B code (injector learn not completed) is often associated with P268B (pump learn not completed) and P0089 (PCV leaking) and are all indicative of some kind of event taking place within the high pressure part of the fuel system (ie HP pump stage, HP common rail, or injectors). The single most common cuase of problems in this area is the Volume Control Valve on the fule pump, which regulates the flow of fuel from the LP stage of the pump to the HP stage and hence regulates the supply to the common rail, which is a rather fragile component. If you do have a recurring fault, it is the first place I would look.
Post #395660 4th Feb 2015 9:40am
Albert s
THANK YOU
Thanks very much for a very comprehensive reply !
Albert S Very Happy
Post #395668 4th Feb 2015 10:16am
Porny
Site Sponsor
If the process hasn't been done... then its a permanent fault. Clearing it will not work.
You need somebody with the correct LR diagnostic kit to do the pump learn followed by the pilot injector learn.
The set-up of the fuel system is critical for correct running and long term durability on a Puma Engine. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #395704 4th Feb 2015 12:55pm
Albert s
thanks
Thanks - is nothing easy with a land rover - Does that mean I have to use land rover dealer to correct ?
Confused
Post #395710 4th Feb 2015 1:01pm
Porny
Site Sponsor
A dealer or good independent specialist with dealer level diagnostic kit.
How far are you from Brigg/Hibaldstow? As I'm up that way quite often and could bring my laptop with me.
Regards IRB
Post #395722 4th Feb 2015 1:18pm
I meant to include in my post that some diagnostic tools won't do the recal on either the pump or the injectors. Nanocom, for example, can clear the fault but not carry out a recal if that is needed. Faultmate however can do all of this.
Porny, do you have any idea what makes the ECU decide that (either a pump or injector) relearn is needed? Obviously if the engine has never been calibrated and there is no calibration data in the ECU, i.e., a new vehicle or new ECU, it will know, but if the vehicle has been running, even if components are changed, what does it actually detect that makes it determine that the process is needed? I cannot see how once there is any calibration data stored in the ECU it can legitimately produce a P167B DTC!
In Albert's case I was rather assuming that the vehicle has been running OK, and that no components have been changed recently, which suggests to me that is more likely that the fault is not due to a lack of calibration but rather some kind of transient occurrence, and clearing the fault may be sufficient.
Post #395729 4th Feb 2015 1:28pm
Albert s
INFO
Hello thanks for your input note:
The fault showed itself about a month ago , the landy was running with no problems then yesterday the eml showed itslf again and currently being relooked at the local garage, note again no running fault showing.
Albert S
Post #395740 4th Feb 2015 2:05pm
Porny
Site Sponsor
Either it's a had a replacement ECU that was not set up properly, it's had a calibration update and the pilot learn bit was cancelled (as technician was in a rush), or it has never been done and checked at PDI from new.
Most of the time it comes down to lazy dealers/technicians.
I need to double check, but I don't think you get a MIL straight away for Pilot learn not done. IRB
Post #395742 4th Feb 2015 2:11pm
