Home > Puma (Tdci) > Lost all drive... |
a oil baffle plate would have to be fitted above the shaft as the top of the casing would be hard to seal as there is a big hole there for gear lever mech
sealing back and front of casing only needs silicone and the standard drain hole sealing then use something like ep140 oil or something that's not going to fling around and up to much |
29th Jan 2015 10:40am |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 |
Does anyone know if the factory are now 100% making sure these splines are well lubricated prior to assembly?
29th Jan 2015 11:00am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
If they got away with it for this long I doubt they will bother now!! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
29th Jan 2015 12:35pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17477 |
29th Jan 2015 12:41pm |
flying_low Member Since: 08 Apr 2011 Location: Masai Mara Posts: 19 |
Rear output shaft seal .... that's the one that leaks into the handbrake, and only requires removal of the handbrake and drive flange, right?
Are they complete morons?[/quote] Yes! They are. Now I have it in writing that JLR will not be able to "assist in this situation" because the while has not been inspected and serviced at a LR dealer. Due to this JLR is not in a position to utilise it's "goodwill budget" towards this issue. So just because I'm remote and vehicle is serviced by me out in the bush -exactly were this vehicle was designed to work- and a lifetime part fails- they won't consider parting with £100..?! I've still saved money and time on doing all the services myself and even the cost of these parts is still cheaper than having dealer work done... I'm still coming out on top here! I have faith in the machine-just not in the people selling it! Ok, rant over. On a serious note- Have been looking at the shaft and coupling I've pulled out-there's a 'snap-ring' on the shaft that I supposed to 'lock' the front - splined end into the adaptor cup. Does anyone think it's possible that this ring could slip or somehow 'unlock' ?? This would presumably allow the shaft to slip backward-away from the adaptor coupling -as it were. This is what it appeared like when I took the shaft and coupling out. Trying to fit them together, it was clear that the snap ring had taken damage from the shaft and cup not being locked together. Could it be tha the shaft was just never inserted properly in the first place? Or would that have led to a much earlier failure? Alternatively- is it possible that rough roads (corrugation) and general dirt tracks might cause the shaft to vibrate out of place? ??? 2011 110 Tdci 1982 Range Rover V8 Classic (Gone) |
2nd Feb 2015 9:29pm |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 |
I've just had it confirmed that I've had my second intermediate shaft fail on my MY09 110. The garage have confirmed that it hadn't been greased when it was fitted 18 months (approx 18,000 miles) ago by another local indy garage (see the start of this thread). Since then I've not done any towing and very little in the way of off roading, so it's interesting to see how disappointingly short their life can be.
Rather annoying, but looking on the bright side i guess it could be worse. Suffice to say I've made sure that thie new shaft will be greased to within an inch of its life... |
4th Feb 2015 4:32pm |
Well mine's showing signs of wear and will be sorted under warranty - interested to know beforehand if there is modification or whether it's a like for like replacement and I may be going through the same thing again in another 10k miles! |
2nd May 2015 3:11pm |
think your find the modification is a bit of grease
2nd May 2015 3:21pm |
You may well be right, it would just be good to know either way. Following blackwolfs posting, I've not seen any reply from someone who has had it done confirming one way or the other. Should be simple to check if there's an extra hole in the casing now!
2nd May 2015 3:27pm |
when I done mine to check for brown dust I drilled a hole in my casing and put camera in , could see very small amount of dust ,so took t/fer for a out proper look/check , all looked ok so just packed with cv grease and refitted
that was roughly year or so ago , just been under to check with camera removed bung I fitted , very small amount of grease spun out (probaley the grease that oozed out when fitting ) round inside casing and joint looks ok and greasy |
2nd May 2015 3:51pm |
ozrob Member Since: 31 Dec 2013 Location: Snowy Mountains Posts: 8 |
Munch90
Are you able to supply a photo of where you drilled he hole to insert the inspection camera? I have a MY13 110 with 66000km and have a big trip coming up at the end of the month...now I am worried. |
3rd May 2015 10:42am |
not got a pic but its about half way along the casing between t/fer and gearbox
all you can see is if there is brown dust inside the casing , you cant see the spline as its got a cover round it of course only a small hole as you don't want to weaken the casing , mines a proper bore camera so only needs a very small hole |
3rd May 2015 10:48am |
Thanks mate,
If I am going to drill a hole for the inspection camera, it might as well be a hole for a grease gun, so I would prefer to drill only one hole. |
3rd May 2015 11:06am |
Now here is a thought,
If the extension housing is basically an empty space where the adapter shaft runs, the gearbox and T/Case is sealed, Why cant the extension housing be filled with gear oil just above the adapter shaft to lubricate it? |
3rd May 2015 11:12am |
