![]() | Home > Puma (Tdci) > 110 USW Interior window trim surrounds (load area) question |
durham Member Since: 02 Jun 2014 Location: Essex Posts: 40 ![]() ![]() ![]() |
Hi Mike
Just popped out and had a look at mine, a 2014 110 USW. Mine is finished with a moulding on both sides which matches the side window surrounds, the centre of both mouldings are open, where the rear windows would go. I'd imagine they are the same trims as fitted to the 7 seat station wagon. ![]() Click image to enlarge Have photographed for your info., Cheers Kevin |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1989 ![]() ![]() ![]() |
Hi
yes the trim is missing, mine is the same as kevins. ![]() ![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Jay Member Since: 23 Apr 2012 Location: Veneto Posts: 27 ![]() ![]() ![]() |
mine is the same as kevins too
![]() but I fitted little rear windows for better visibility Jay |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Mine has them to, guess you know by now yours is missing them. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
MVS Member Since: 20 Sep 2014 Location: N Yorks Posts: 16 ![]() ![]() ![]() |
Many thanks chaps!
I thought it should be there! I personally think the Dealer (LR franchise) just don't want to cough up for it having lost it whilst adjusting the hinges at some point. I have to say I only noticed whilst fitting the TGE insulation/trim panels ![]() |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
I was thinking of fitting the rear quarter windows, as it definately helps with reversing, all the 90 USW I have driven have these fitted already, anybody know why the 110 doesn't ? Cheers Keith |
I don't know, but when the ex owner of my landy fit the rear close panel, he must made the hole for the quarter windows because there weren't Jay
Flyingfocrs Member Since: 12 Jan 2015 Location: Deepest darkest Aberdeenshire Posts: 155 ![]() ![]() ![]() |
All to do with the van classification for VED purposes. Utility station wagon doesn't get the rear and side windows to classify it as a van same as 90 & 110 HT's. Mike |
^^Unfortunately you're wrong there. All Defenders are now classed Commercials essentially, regardless of wether it's a station wagon or hard top. Also, on a Hard Top you can choose wether you want the rear whether windows of not, so not having them has nothing to do with their classification. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
GrahamGParker Member Since: 12 Jul 2011 Location: Wiltshire Posts: 6 ![]() ![]() |
I understand this is an old post but It looks like you guys would know.
I need to remove the rear trim on my TDCi utility and am having difficulty. I don't want to force it and breaj=k it. The top clip is not attached so I can see the clip on body work and the riveted piece that the clip fits into but still can't seem to free the bottom one. Which way do I need to pull it up , down , towards the front ?????? I have just bought myself a set of clip removal tools if that helps. Cheers Hope someone can give me a step by step guide btw hope you got the trim from your dealer |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
Just pull it straight out (as in towards the front of the vehicle) - no knack to it just pull harder if it doesn't come off.
The clips are friction fit onto the body work and made of cheese, they'll probably break when you remove them so grab a couple of spares 60p from a dealer or online. |
As said above but start at the door opening edge and not in the corner. Don't make old people mad.
Sockpuppet ARC99
Appreciated Ill give it a go ![]() |
