Home > Puma (Tdci) > Grease nipples
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Grease nipples
Where are all the grease nipples located on a 2.4 puma. What is the recommended grease to use?
Post #393606 29th Jan 2015 11:28am
MartinK
Mainly the prop shafts.
see
http://www.defender2.net/forum/topic29299....rop+grease
http://www.defender2.net/forum/topic27305....rop+grease
http://www.defender2.net/forum/topic8258.h...rop+grease
One or twice a year (more if wading). I just do mine once a year, and also when I'm changing lubricants on the gearbox and transfer boxes (something to do whilst you're waiting for the old oil to run out Thumbs Up ) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #393627 29th Jan 2015 12:17pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Propshafts of a Puma don't always have nipples, some are sealed for life.
UJs (4) do still have them.
Post #393642 29th Jan 2015 12:45pm
Then there are the ones where the factory simply omitted to fit the propshaft nipples.
There was a TSB on the subject some time ago, and if you spotted the omission before the warranty expired and asked, your dealer would fit nice new propshafts for you.
Post #393651 29th Jan 2015 1:01pm
Thumbs Up
Models LD - Defender
Title Defender Front and Rear Propshaft Grease Points
Last Modified 30-MAR-2009 08:27
Category Noise/ Vibration
Symptom 703000 Vibration Concerns
Content
Issue: Loose or missing front / rear propshaft grease nipples for Defender 07 MYonward vehicles.
Action: If any propshafts are identified where the grease nipples are missing, then the propshaft should be replaced.
Any cases where the grease nipples are in place but loose should be torqued to:
8Nm + 45degrees.
Post #393980 30th Jan 2015 9:46am
zone30
Tried that one, but there are PropShafts with on nipples, sealed for life!
Post #394002 30th Jan 2015 10:57am
They're the ones where not only did they forget the nipples, they also forgot the holes for the nipples! Rolling with laughter
Post #394045 30th Jan 2015 1:15pm
