![]() | Home > Puma (Tdci) > Puma 2.4 turbo actuator mechanism |
you need to disconnect the arm from the motor actulator before seeing if it will move , there electric operated not vacuum like a td5
Partyranger Member Since: 27 Oct 2014 Location: Gauteng, Pretoria Posts: 13 ![]() ![]() ![]() |
Ontdekker I see you are pretty close.
Take your landy to Walter at LRXtreme, they're in PTA east. I too had an issue where the Puma would run in a reduced power mode, it seems as if my problem was a stuck EGR valve. PM me if you want any further details. |
Ontdekker Member Since: 25 Nov 2009 Location: Centurion Posts: 11 ![]() ![]() ![]() |
My EGR is blocked. (by Walter)
Mine was the first puma EGR blocked by Walter.
I then also had that strange reduced power mode for a long time. They then unplugged it and it seems like everything is back to normal now. Give it a try. Hopefully it will sort your issue as well. |
