Home > Puma (Tdci) > Clutch Issue
Page 1 of 3 123>
Morepower
New Zealand
Clutch Issue
Hi Guy's... Just a quick one... My 110 went in for it's B Service... The Dealer said the clutch needed replacing as there was an occasional rattle from underneath... However now the clutch is very snappy and bites almost immediately and very severely, with little or no adjustability. It seems that's it either in or out... I have also noticed that under certain conditions that I now have bad clutch judder..
The clutch bite and slip characteristics where fine before, There was just an occasional rattle... Has anybody got any idea's whats wrong?... It's back at the dealers on friday and I'd like to be fully armed when I go in..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #393433 28th Jan 2015 8:30pm
bob neville
Hi Tim
Had a similar problem on my 110. It took a visit from a LR engineer to sort it out, and the fix was very easy Thumbs Up
The Tdci's have the same adjustment system as the TD5's under the bonnet where the cylinder is. Apparently this was not mentioned in a lot of the documentation hence the reason the dealer could not find the problem.
2013 Defender 90 CSW - sold
Post #393455 28th Jan 2015 9:02pm
Morepower
New Zealand
Thanks Bob, Can you elaborate...Or better still tell me what I need to do...
Kind Regards
Post #393458 28th Jan 2015 9:06pm
bob neville
Hi Tim
Second post from this forum post.
http://forum.lro.com/viewtopic.php?f=18&t=39674
The Tdci clutch pedals are supposed to be set for life but, sadly, that is not the case as I found out when my 110 was off the road for six weeks trying to get it fixed. It was my second new clutch in a year, the first was fine when fitted and then fell to bits ! Dealer replaced it and I had the same problem as you have, clutch bit about 1/2" off the floor, either on or off and clutch judder. Dealer did numerous things on the advice of LR, took clutch out and put it into another vehicle, special pressure bleed etc etc all because the clutch travel is set for life.
After replacing the clutch, all pipework and numerous other bits, LR sent an engineer out and he fixed it within 30 minutes by adjusting the pedal travel as per the link above.
Post #393462 28th Jan 2015 9:22pm
Morepower
New Zealand
Thanks Bob... I think I'll have a go at it tomorrow
Post #393469 28th Jan 2015 9:48pm
bob neville
Make sure you remove mats etc, measurements are from the bare floor.
Good luck Thumbs Up
Post #393471 28th Jan 2015 9:51pm
Morepower
New Zealand
All Done Bob... Seems I have a Clutch again!!!!!... Bow down Why can't the dealers do this??? Big Cry .... I'm still going in tomorrow, So they can inspect how it should be done... Laughing
Post #393883 29th Jan 2015 10:06pm
Caterham
Shocked
I thought I had the death rattle and required a new clutch after the above symptoms albeit intermittent (and recently more bad that good!!)
I hope this is the fix...... Thumbs Up
- ironic too I'd come on here to look for death rattle and before I did looked at new posts only to find this Thumbs Up
Morepower - you have a clutch again. does that also mean the clatter when you turn off / clatter from underneath has gone too ?
Post #393944 30th Jan 2015 7:12am
MY12 Workshop manual states:
Check distance from lower edge of clutch pedal to down position. Correct measurement is 135 mm (5.31
in).
Adjust master cylinder push rod lock nuts untill 135mm (5.31 in) is achieved.
Tighten lock nuts to 23 Nm (17 lb.ft).
Move the clutch pedal to the fully down position.
Tighten nylon nut securing push rod to clutch pedal trunnion to 23 Nm (17 lb.ft) .
Install a new gasket to cover plate and secure with the 6 screws.
Tighten the screws to 3 Nm (2 lb.ft).
I think the adjustment is essentialy the same as the TD5 but it looks like they measure the range of movement of the pedal rather than the floor to pedal distance at rest.
Post #394008 30th Jan 2015 11:09am
Morepower
New Zealand
I had the death rattle from the clutch like many on here... The Dealer replaced the clutch under warranty... However, they forgot or didn't adjust the clutch to take into account the new clutch fitment...
Interesting to note that even with the new clutch fitted that the truck drove horribly... Once the clutch was adjusted as per Bob's info... The snatch and clunk has pretty much disappeared... Which leaves me to think that the rev hang etc is timed based on clutch position. I expect they've set the clutch engagement/rev hang to match... My truck drives perfectly now, which it most certainly didn't with the clutch out of adjustment...
Post #394069 30th Jan 2015 2:30pm
Caterham
thanks morepower.
so following the clutch replacement did it still rattle or did the clutch adjustment only resolve the biting / clunk problem?
Post #394073 30th Jan 2015 2:40pm
munch90
did they replace the master cyl ?
you should not have to adjust the pedal just because it had a new clutch fitted only if the master cyl was touched
Post #394074 30th Jan 2015 2:41pm
Caterham
perhaps the clutch was poorly adjusted from the start?
Post #394080 30th Jan 2015 2:59pm
munch90
maybe , but should never need to adjust unless the master cyl has been changed
Post #394087 30th Jan 2015 4:28pm
Caterham
So assuming it was set up right it should never need adjusting unless you change the master cylinder.
So my on/off clutch action which is becoming more frequent is more likely the clutch plate needing replacement rather than a simple adjustment of the clutch pedal.
I live in hope.
Post #394091 30th Jan 2015 4:40pm
Page 1 of 3 123>
