Home > Maintenance & Modifications > Will rear window trims fit with mud rear side panels?
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Just wondered whether anyone had managed to fit the CSW trims which go around the little windows either side of the rear door into a HT with the MUD side panels fitted?
I've recently fitted the MUD panels and just need to do something with those rear window panels to finish it off.
If anyone has any other ideas they'd be greatly appreciated too. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #393074 27th Jan 2015 7:19pm
Les Brock
Bit awkward but here's mine
Regards
Les
Post #393211 28th Jan 2015 8:20am
Les Brock
Err........Pic was ok this end Whistle
Post #393212 28th Jan 2015 8:21am
TDCi Guy
Thanks for those Les! I'm guessing that finishing strip is where you've had to cut the panel? Tom
@tditomprice
Post #393253 28th Jan 2015 10:41am
Les's trims are TD5 of course not Puma
Post #393256 28th Jan 2015 10:45am
Les Brock
Yep - Sorry Didn't notice the TDCI Guy Bit Whistle
But, yes the finishing strip is the section I cut out, I have pics of what I did if you want me to post them up?
Post #393257 28th Jan 2015 10:49am
TD5 trims will fit a Puma, no problem (assuming you have no rear seatbelts) I just wanted to point it out as Puma panels are quite different and are missing the part nearest the outside - So TD5 panels would probably suit better
Post #393258 28th Jan 2015 10:51am
steve E
Wales
Do you have rear windows in your 90 HT or is it just to look nicer inside?
Steve
Post #393274 28th Jan 2015 11:39am
TDCi Guy
Yeah the TD5 panels will fit mine no problem, I don't even have the small rear windows in mine, I was just going to carpet/put something useful in the window hole.
Les I recognised your name from LR4x4 so popped over there to look on your build thread and saw the relevant post. Very useful! Looks like you're almost there with your very meticulous project too, all the best! Very Happy Tom
@tditomprice
Post #393275 28th Jan 2015 11:41am
steve E
Wales
Thanks for the reply
I'm following the rear HT threads so I know how to do mine when the time comes.
Thumbs Up
Post #393284 28th Jan 2015 12:09pm
Les Brock
Thanks Tom Thumbs Up
Post #393296 28th Jan 2015 12:40pm
TDCi Guy
Thumbs Up
I've tried to go the practical route while keeping it as 'plush' as possible.
I managed to get the full rear rubber load liner thrown in with the purchase, I've fitted the rear headlining piece and wired in the interior light and also fitted a bulkhead removal bar.
Obviously now I have the MUD side panels and I'm looking to finish off the rear window panels.
I've also ordered some proper automotive carpet to cover anything that is still bare paint in the rear, after that I think the rear is pretty much finished.
Most of the above is documented in my build thread with shoddy pictures to go along with it. Tom
@tditomprice
Post #393359 28th Jan 2015 4:52pm
