Home > Puma (Tdci) > Coolant Top Up |
That's not unusual, so I wouldn't worry about it at all. Along as you're not constantly doing it, and therefore diluting the coolant in a significant way, a it's fine.
Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
25th Jan 2015 5:18pm |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
Try a new cap if you have to top up frequently. If you do a search you will find it is a common problem and fix.
25th Jan 2015 5:21pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5664 |
All my defenders have always been constantly lower than the level line. If I top up, it pushes a bit out and sits at the level you mention.
Andy |
25th Jan 2015 5:44pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
Mine has lost about 1 cm regularly since new, slightly more if I ignore it for a year. Now nearly 2 yrs old and 21K miles.
Did go back to the stealer a couple of times originally but they never found any reason or cure. Seems to be something it's OK to live with. Cheers. 2.2 90 XS 88" Series One Old Norton Minerva |
25th Jan 2015 6:34pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
Gum, I topped it up with coolant not water as we had a bottle from when my RCZ sprang a leak. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic 2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
25th Jan 2015 6:55pm |
Check your power steering fluid too ... Some new cars have just enough
25th Jan 2015 8:40pm |
