Home > Technical > Interior light
Sidcoupe
Scotland 2008 Defender 90 Puma 2.4 HT Cairns Blue
Interior light
Can anyone help ? How do you remove the interior light on a defender
Post #392351 25th Jan 2015 11:57am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Take the clear lens off and there are a couple of screws inside IIRC
Post #392358 25th Jan 2015 12:23pm
Sidcoupe
Thanks for the reply I've just checked there are only 2 screws which are live Rolling Eyes
Post #392371 25th Jan 2015 1:20pm
ibexman
Not screws nuts Thumbs Up
Post #392376 25th Jan 2015 1:37pm
Cupboard
Start by carefully wiggling a flat bladed screwdriver in the slots font and back which will pop the frosted bit off.
There are two 13mm (IIRC, they might be 10mm) nuts that hold the lamp unit on to a backing plate that clamps on to the headlining. There's a plug that takes permanent 12V and switched earth from the 10AS to the unit (purple and purple/white wires) and I can't remember off the top of my head what happens to the earth, I think it might just plug straight on to the backing plate. My memory's going, I only did it three weeks ago Whistle
When re-fitting it it's very easy to short the 12V feed to something and it's really fiddly to get the backing plate back in and lined up properly. Once you do it all just slots happily in to position. If once you've put it back together again the clock stops working and the light doesn't work, you've blown the fuse.
Post #392382 25th Jan 2015 1:49pm
