Home > Maintenance & Modifications > Finally fitted my Christmas present |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Quote
"As for not being pedestrian friendly, the door mirror would have smacked the pedestrian head, the rock and tree sliders would have taken their knees out, the wheel flare would bruise their thighs all before reaching the bumperette The rear bumperettes are well within the widest point of the body work." Yep that's the plan, now step away from my truck. My bumperetts. Click image to enlarge Andy |
24th Jan 2015 7:22am |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
What if your reversing?
24th Jan 2015 7:59am |
Nice bumperettes and great 'attention to detail' with the bolt head caps. They look great! If you go through life with your head in the sand....all people will see is an ar5e!!
24th Jan 2015 8:12am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
i bought those a few months ago. Very pleased and nice and strong. 1953 80" 1987 mini city e 2011 90" |
24th Jan 2015 10:55am |
Smilesapart Member Since: 28 Sep 2013 Location: Suffolk Posts: 735 |
Not very pedestrian friendly? Not very pedestrian friendly??!!!
Are you taking the ? A lad riding a bike is not very pedestrian friendly. Cars for a decade have had to become ridiculous ugly fat bonneted shaped monstrosities to be more pedestrian friendly. But since when has there ever been anything the slightest bit pedestrian friendly about a Land Rover Defender? And it's all the better for it. The best pedestrian friendly advice I can give is 'stay walking on the pavement out of my way and then I won't hit you with my truck! |
24th Jan 2015 4:38pm |
Ironically enough I may be wrong here but the Defender not being 'people friendly' (inside or out) aren't they just a cnother couple of reasons why production is ending?
"You are my crumple zone!" Or seen on a rear crossmember with an arrow "Your skid stops here!" If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Jan 2015 4:50pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Like I said they have already paid for themselves on mine. All I have is a bit of White paint but the transit had a big dent. 110 Hardtop
24th Jan 2015 4:54pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I'd love a set of these, but I've got a rear ladder and it won't clear the bottom step. Unless I cut the bottom off of course. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
26th Jan 2015 11:15am |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
Click image to enlarge My neighbour in Chur has these ... twin tubular steel, welded and bolted to the rear, also 'loose' down the side. I poked and that steel could be used to pull it upright after a roll over .. The Kantonal 'MoT' is as strict as anything in the world, other posts have noted that any mod at all in Switz. needs 'TUV' certs. So where ever they came from, they are sound, might ask for info Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
5th Feb 2015 2:29pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
I've got a set of these brand new in the box in my shed.
went to fit them but they push against the mud flap bracket. Caterham had the same problem and his have pushed the mud flap bracket backwards. I phoned the supplier who weren't to helpful, hence been sat in the shed for 18 months or so. I suppose I could use a spacer to bring them back slightly. Has anyone else experienced this with fitting to a 110 SW? |
5th Feb 2015 3:34pm |
Well I had no such trouble when fitting them to my 110 SW
5th Feb 2015 4:25pm |
Thanks for the reply.
I'll take another look when the weather picks up |
5th Feb 2015 4:53pm |
