![]() | Home > Puma (Tdci) > Front door linings |
Once you have all the bits off. Pull the bottom away from the door to release the poppers then lift or slide it up to un-hook it from the top. If you don't want to break the poppers then get a trim removal tool. I would pop in to the dealer and get a few spare poppers if I were you
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Thanks AndrewS, I thought the trim clips might cause a problem.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Whilst poping the door off and peeling back the spray film is easy and ive done it many times
i wont do it to waxoyl the new one. Too much to break - what i will do is do it at 2 yrs 09 months old - if its has rusted back to the dealer - if it hasnt ill treat it Mike |
