Home > Puma (Tdci) > Miles per tank in a 2.4
Page 2 of 2 <12
leeds
landy andy wrote:
Ok then Davie L, if you want to play this game more details required.
90-110
Road tyres?
Who's map
Type of roads?
Whistle Whistle
Andy Thumbs Up
You need more information then that Andy.
On range we can exceed any of the figures already mentioned with our 110's exceeding 600 miles per tank and one should be approaching 1,000 miles. Good on those long journeys.
However some people might accuse me of cheating!
MOI? Rolling with laughter Rolling with laughter
Never! Whistle
Defenders are so adaptable Thumbs Up
Brendan
Post #391381 22nd Jan 2015 10:34am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Big Cry
YAWN!!!!!!
Post #391424 22nd Jan 2015 12:10pm
Caterham
Stiff1 wrote:
420 on 2007 110. seen on here someone gets 500, that must be a lot of down hill.
Whistle - you mean 600+
Mr. Green
Post #392097 24th Jan 2015 2:52pm
K9F
Hi Wayne,
Constantly keeping your vehicle below 2000rpm trying to squeeze out a few more miles per gallon is why you hear all your rattles and squeaks and end up chasing shadows for non-faults..
How's the latest saga going?.....On reflection no real need to reply.
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #392098 24th Jan 2015 3:02pm
Caterham
no no I'm happy to respond (more than happy !).....
Swansea and back yesterday (c300miles)... the only real fault I have was I had to fill up at only 491 miles Sad
(took some great photos near Breacon - will post later but f - in busy at the moment ......)
any how after popping into Likes at very nice chap there mentioned a lot of these rattles could be psychological?) Embarassed
either way I now have my flint stone drop out floor panels for when my extension shaft, linkage rod, transfer box, abs modules and calipers all fail which as I'm sure we all know are intricately connected as is the air that seems to be getting into my washwipe spray which is a result of the annoying rattle seems to have developed since applying some more acf50 to the rear crossmember?
other than that all is going well - just the usual inconsistent rattle / clutch / gear engagement (the bloke at Likes also mentioned about the clutch / spring bit can stick / be stiff.........as I've thought before perhaps a new clutch is order of the day?
how you going Mal?
Post #392105 24th Jan 2015 3:27pm
K9F
Off Topic
Hooked up with Rustyboxx today, went to see a tidy W plate TD5 with 60k miles on the clock and took my Landy that hadn't moved since October for a whirl. No sqeaks or rattles, psychological or otherwise.....24-27mpg (never expect or try to achieve more since the day I bought it).....happy as a sand flea at that!
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #392109 24th Jan 2015 3:49pm
Caterham
good for you (no really I am pleased for you).....
but that's like rubbing salt in my wounds.....barely seen daylight now for best part of a couple of weeks. (No overtime pay either).
and you're off jollying looking at td5 and more to the point no squeaks nor RATTLES (grrrrr).
Off Topic
sorry.
here's one from my gallery.
Post #392110 24th Jan 2015 3:59pm
wildrover
Why the clever arse replies - the guy was asking a question.
Yes we have a 2.4 and I don't know the actual MPG after 36,000 miles. Could be interesting to know?
Post #392226 24th Jan 2015 9:41pm
Caterham
oops - I hope that wasn't aimed at me Shocked
611 miles on a tank equates to 37 mpg
normally getting 450 - 500 miles which equates to c 33 mpg.
above mpg's are from memory sorry (you'll have to do the sums to confirm).
Post #392231 24th Jan 2015 9:53pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I've got an 07 2.4 110 xs SW with roof rack and lots of kit in. 150,000 miles now.
I drive at normal speeds over a wide range of road types including motorways and cornish B roads and normaly get 400 miles out of a tank before the yellow light goes ping. (75lts in a 110 tank) so I think that makes about 28-30 mpg ish.
I drive arround the 2000 RPM mark most of the time when in the upper gears, but dont rev the engine beyond 3000 revs before changing up.
hope that this helps Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #392271 25th Jan 2015 6:42am
landy andy
My best is brimmed tank in a 110 and got 217 miles.
Andy
Post #392278 25th Jan 2015 8:26am
CatherineF
I think ours is about 300 miles on a tank. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #392281 25th Jan 2015 8:38am
Page 2 of 2 <12
