Home > Puma (Tdci) > blinker issue
benn01
Brazil
blinker issue
I have a set of fog lamps wired to the high beams...purchased the defender that way and havent gotten around to setting them up properly. Anyway, very often a fuse for the blinkers will go. I was driving last night and the left indicator no longer flashes it makes a buzzing sound and lights up solid. I'm not sure what is going on and if the high beams/fog wiring are even related. any help greatly appreciated
Post #390854 21st Jan 2015 4:11am
K9F
Flasher relay would be my first port of call. Get a multimeter (or someone that has one and knows how to use it) and your problem will be located in no time. The fog lamps should in no way interfere with your indicators if they have been wired in correctly and the indicators were working. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390884 21st Jan 2015 9:25am
Not helpful to your problem, I am afraid, but what on earth is the point of fog lamps wired in with main beam, it is utterly pointless! The only time when fog lamps are useful is a time when you really don't want headlamps on at all, let alone on main beam.
Or are they really spot or driving lamps?
I agree with K9 that the flasher unti is a possible suspect but it is curious that left fails and right works, since the same flasher unit is used. It could be a problem related to the load on the unit (caused perhaps by a short in the NS indicator circuit or a dud bulb). What happens if you switch the hazards on?
What happens if you take the NS indicator bulbs out and turn on the NS indicator (obviously they won't flash but does the buzzing stop)? This might help to differentiate between a harness fault and a bulb fault.
It is hard to see how the fog lights could be a contributing factor, but the fact they've been wired as they are raises questions of competence about the person who last messed with the wiring!
Post #390898 21st Jan 2015 10:06am
K9F
Idea Adding to Blackwolf's good suggestion about the indicator filaments etc. Could it be possible the fogs do have a short and have a shared earth perhaps with the left hand front indicators? Disconnect the fogs, remove the fog fuse (if they've gone as far as fitting one) or take the fog filaments out first and try again.
We could theorise all day long, every day on this one, get a multimeter as said. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390908 21st Jan 2015 10:14am
benn01
Brazil
The hazards are working. I have replaced the flasher relay before and it did not solve the issue. Im going to test this over the weekend with the suggestions and my friend who is an electrical engineer and post back up here. Thanks so much.
Post #391317 22nd Jan 2015 7:21am
The fact that the hazards work narrows down the problem quite a lot, since it suggests that the bulbs and all the wiring between the dash and the bulbs is OK, although it does in many ways make the problem even stranger!
Please let us know how you get on and what you find - you certainly have and "unusual" fault!
Post #391355 22nd Jan 2015 10:23am
landy andy
Have you checked the switch?
Just sounds like a failed switch that is not making full contact and so is arking causing the relay to buzz.
Andy
Post #391417 22nd Jan 2015 1:01pm
benn01
Brazil
I am hoping to work on this over the weekend, ordered a switch and relay last night. I was thinking it could be the switch because I had another one go bad a few years back.
Post #391572 22nd Jan 2015 9:35pm
benn01
Brazil
My arm is in a removable cast at the moment so unable to work on it for another week or so...did upload a video and I think it may be be both a switch and a bad bulb. The right side was not doing the fast blink as of a few days ago.
Post #392462 25th Jan 2015 6:33pm
Are there LED's fitted?
Post #392463 25th Jan 2015 6:36pm
benn01
Brazil
No, I was going to fit the WIPAC led kit and fix the fog lamps at the same time.
Post #392466 25th Jan 2015 6:43pm
I see, the standard relay would flash like that with LED's due to the lack of resistance, is there good contact on the bulbs/ holders? Might be worth checking.
Post #392475 25th Jan 2015 7:02pm
benn01
Brazil
Wouldn't a bad bulb do the same thing for the right blinker?
Post #392496 25th Jan 2015 7:27pm
benn01
Brazil
so this issue resolved itself when I switched to the wipac leds.
New issue, the high beams flash when I put the directional blinker to the right. Bad switch? Related?
Post #408780 18th Mar 2015 7:47pm
benn01
Brazil
anyone?
Post #410265 23rd Mar 2015 7:35pm
