![]() | Home > Maintenance & Modifications > Replacing a Td5 Alarm unit? |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Contact a professional alarm company.
First its not appropriate to discuss on an open forum Second I would only fit a decent alarm that is thatchman and to keep the rating, by a professional installer. third you cant just short some wires its a professional alarm fitted Mike |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
Bit more than shorting some wires together - but not hard to remove the immo function from a Td5. In saying that, there is more than one way to do it depending how far you want to go. Even professional alarm companies don't know how to do it... which often means you end up with 2 key/alam fobs on Defenders. You can get a upgrade kit to make a standard LR alarm CAT 1 - which means you just keep the LR key fobs... you just need to ask the right people ![]() Feel free to PM me for more info if needed. Ian |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Sorry to sound cynical, and my sincere apologies if this causes offence......but 1st post here and asking about how to bypass the immobiliser on a TD5?
I'm not sure you'll get much luck with answers here fella. Mark 2011 110 XS DC Stornoway Grey |
Or should anyone help...especially with the rate of thefts. Mike |
There are 2 ways of not needing the LR key fob anymore.
1. The TD5 can be programmed in a way it doesn't need the keyfob anymore or 2. Bell auto services can do something with your ECU that it doesn't look for anymore for ths As10 alarm ECU so no key fob neede either. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
