Home > Puma (Tdci) > Heater fresh air/recirculation selector broken
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
On the way into work this morning I have managed to break the fresh air/recirculation selector on the heater controls. I pushed it over to recirculate and there is now no resistance when selecting between the two and the heater is stuck on recirculate.
I havent had the dash apart before so Im not sure how it operates but I assume it operates some kind of cable which could have popped off? Any pointers? Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #388002 13th Jan 2015 11:36am
Yes it's by cable, I changed one.
It will either be snapped or more likely bent so it doesn't go back into the sheath
Never fear though, a new one is about 8 and worth it just to swap.
This cable goes through the bulkhead and out to the intake ducting the top right of the engine bay.
If you look there you will see the same cable and a nylon plastic arm...
All you have to do to remove it is in-clip the cable outer from the retaining clip and the same for the cable core as it has a loop on both ends.
Trust me, it's a cheap easy swap, hardest part is threading it though and that isn't too bad even.
It may be jammed by a stray cable too which may have caused it.
Post #388012 13th Jan 2015 12:08pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had this happen to me on the 90.
Turned out the dash end of the cable had become kinked as the other end had become stiff due to lack of use. Managed to get it straightened out without changing the cable
Rosco 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #388115 13th Jan 2015 7:22pm
theorangebandit
Mine did this, it bent and slipped off the hook. So being the man I am I stripped the dash out found the fault and forced a toothed washer on top and squirt wd40 down the sheath but one or two uses later it popped off again. So I lifted the bonnet and moved the lever to fresh air and haven't thought about repairing it since. Its been broken for over a year now lol simply not a feature I utilize despite the low cost and ease of the repair I'm not bothered about it lol
Post #388125 13th Jan 2015 7:30pm
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
My cable has come off the selector and for the life of me cannot work out how it goes back on, just cannot get the eye onto the ‘pin’.
Help……
Post #933183 11th Dec 2021 12:09pm
MattyEssex
So managed to get it in but pops off every time recirculating is selecting which suggests cable not moving freely….. think it will be engine selected winter straight through air and summer recirculated for wife’s hay fever … if I remember
Post #933184 11th Dec 2021 12:29pm
