![]() | Home > Off Topic > Q? for the chainsaw users. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
not sure if this is a daft question or not. im thinking about buying a small 14inch petrol chainsaw for very infrequent use
(firewood) . i have a pile of old sawn timber like fence posts, 4x2s etc etc. will the chainsaw cut these OK or should it only be used on fresh "wet" wood? My 109 thread my youtube channel |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1595 ![]() ![]() ![]() |
It will cut through fence posts no problem. However watch out for nails, tacks and just general dirt. Even a bit of soil takes the edge off the saw. With a smaller saw the chain is lighter and easy to damage. So it might be worth jet washing the posts clean first.
Also if you can don't cut on the floor. Try and raise the posts up, this will reduce any chain damage. |
Old timber normally blunts the chain bit quicker
OLD FENCE POSTS , MIND OUT FOR NAILS OR STRAY BITS OF WIRE LEFT ON THE POSTS THEY CAN BE LETHAL [/b] |
![]() http://www.defender2.net/forum/topic27424.html?highlight=chainsaw If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
cheers guys just wanted make sure
![]() my youtube channel |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20737 ![]() ![]() |
I have not long got a new reciprocating saw, 18v surprising what it will cut though.
Fast cutting and can cope with or without nails in safety. |
I've used reciprocating saws but always found them much slower for chopping wood. Although they do make mince meat of a disco 2 lol
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
I have a Husky 135 for pretty much the same reasons - home firewood. As has been said watch out for nails etc but one thing I would say is don't scrimp on gear (helmet, gloves, trousers etc) if you do get one as it'll go through your leg without trying and they tend to not leave nice clean cuts.
^^^Wise words^^^
![]() Also budget for chainsaw oil as well as 2 stroke, a few files for blade sharpening and perhaps a spare blade to keep in stock. Most importantly be aware of how to use the saw correctly and aware of the danger of kickback. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 ![]() ![]() |
Unless you have no 240v nearby, I'd go one of these.
http://www.screwfix.com/p/evolution-rage3-...230v/26612 Rich semper in excretia sumus solim profundum variat |
Probably a bit safer for a few bits of rough sawn timber but when all is said and done not really the right tool for firewood in my opinion
That's what the OP said he had a pile of to cut. Rich
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
+1 for this,Ive had mine for a year and it's just the job.The blade even cuts through nails,so no need to worry what type of wood you slice up.Sometimes they have them on special in Screwfix. |
Forgot to say that I have a woodburner and never buy wood,just shovel the nails out once a week
