Home > Technical > Ignition Relay
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Ignition Relay
Hi guys
Can anyone tell me where the ignition relay is located in a 1988 90 2.5td please Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #387710 12th Jan 2015 1:35pm
Should be down behind the gearstick in with the fuses... there's usually 4 or 5 relays along the bottom.
unscrew the fusebox lid with the two large thumbscrews.
Post #387722 12th Jan 2015 2:56pm
cornish rattler
Cheers jim, you wouldn't know which one it is would you Thumbs Up Graham
Post #387724 12th Jan 2015 3:18pm
roel
Isn't that mentioned on the inside off the lid? Roel
2003 90 Td5 (2009-now)
Post #387725 12th Jan 2015 3:20pm
cornish rattler
are right ok Thumbs Up Graham
Post #387726 12th Jan 2015 3:23pm
cornish rattler
Son is going to see if he can buy one from work if not check it and see if he can do anything before he comes home tonight Smile Graham
Post #387734 12th Jan 2015 4:11pm
cornish rattler
The lid ( my lid ) anyway doesn't tell you anything as the sticker thingy is missing, we have removed the metal cover and found the relays but not sure which relay is for the ignition as they all click when the ignition is turned on.
any ideas as this switching off problem is driving us nuts Confused Graham
Post #390273 19th Jan 2015 6:07pm
munch90
can you feel them click when switching things on and off , might be lucky and find it that way
Post #390276 19th Jan 2015 6:17pm
cornish rattler
Will have another look at the weekend and let you know Smile Graham
Post #390451 20th Jan 2015 12:17am
