Home > Maintenance & Modifications > JE Eng Suspension
harveyg77
JE Eng Suspension
JE Eng seem to offer miracle suspension that improves a Defender. Is it any good? Does it smooth the pitching and harshness at all? What other options are there for improving ride? I don't want to fit heavy duty stiff as feck springs and crossing the Sahara at 10-tonnes shocks. Just a normal family hack that want to be made as smooth and comfy as possibly, without loosing height and preferably also improoving the handling.
Thanks in advance,
Harvey
Post #38771 21st Aug 2010 7:33pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Put some Bilsteins shocks on it you will feel the difference Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #38773 21st Aug 2010 7:53pm
Porny
Site Sponsor
Re: JE Eng Suspension
Thanks in advance,
Harvey
I've never found the suspension to be that bad ref: spring rates, but a Fekete says a good set of dampers will make all the difference. Though, if the spring rates are too hard for you usage, dampers won't hide this.
You can also fit an uprated rear anti roll bar to control the body roll a bit more... the standard front one isn't too bad if fitted.
If your 110 hasn't got anti roll bars at the moment, it will have all the brackets so easy enough to fit.
I can supply anti roll bars etc etc if required, with a bit of forum discount.
Ian
Post #38782 21st Aug 2010 9:44pm
harveyg77
Thanks for the replies and offers.
She is a 110 XS utility and has front and rear roll bars. How can I tell if she's got normal or HD springs? How can I tell whether my problem is too high a spring-rate?
Bilsteins are good shocks then? There are that many and so many people fit them I'm out of sorts. I assume Britpart, OMEmu, Terrafirma, etc. are nothing on Bilsteins for a regular vehicle like mine?
Thanks Harvey
Post #38798 22nd Aug 2010 6:25am
K9F
Blimey Harvey...Question overload.....
I have a 08 XS that came with HD suspension, I admittedly drive mine like a go-kart and it handles exactly as I want it too and I feel safe and secure....The vehicle has further capabilities I am sure but they are above and beyond my confidence thresh-hold and that of my 'warm comfortable feelingommeter!' If you can say the same forget the shocks and look for and spend the money on something else.
There's my pennethworth in an attempt to answer the lot!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #38813 22nd Aug 2010 8:18am
Martin
Site Admin
Ian can I interest you in sponsoring the site, so you can do this without breaking the rules...? Whistle Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #38836 22nd Aug 2010 12:25pm
Porny
Site Sponsor
hrmmm... lol.
Martin, you have a pm.
Ian
Post #38889 23rd Aug 2010 11:31am
harveyg77
Porny,
Can you please provide a response to Martin to discuss your commercial interests.
EDITED HG 10:00 060910
I have both a front and rear anti-roll bar on my Defender. I've spend about 5 minutes checking my springs and the only colour I can see is yellow all over the front two.
JE have told me they use Koni shocks and up-rated anti-roll bars, but Koni do not seem to list anything for the Defender. Also It has been suggested that Bilstein will improve my ride, but the only items listed are a 'sport' which don't seem to imply they are ride friendly.
As a side issue, is it over or under damping that is causing me to be unsatisfied with the ride?
I feel she pitches and jars too much over bumps, I can't decide if this is because the shocks are not allowing enough/quick enough absorption of the bumps, or whether the shock is allowing the spring to return to quickly from a bump.
Thanks,
Harvey
Post #39995 6th Sep 2010 8:37pm
Martin
Site Admin
Yes he has, but I've not had anything back yet Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #40003 6th Sep 2010 8:54pm
