Home > Expedition & Overland > Secure boxes to rack? |
On long (overland) trips I have a metal ex army box bolted (from inside) to the roof rack. I also made a subframe from alloy angle, two alloy army boxes fit exactly in it. The frame is bolted to the roof rack, and I can secure the boxes to the subframe with a metal strap and pad lock.
I do not have a detailed picture currently, but to give an impression: Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite Last edited by VeeTee on 6th Jan 2015 5:09pm. Edited 1 time in total |
6th Jan 2015 5:04pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
I have not come across a good secure system for fixing different boxes to a roof rack yet.
If your rack is one with Tee slots in the rails you could slide bolts or uni strut nuts down the channels then you could drill a couple of holes in the bottom of your wolf boxes and bolt them onto the racks. OK you still have the problem that the lids can be opened and contents removed. If you were using something's like Alu boxes you could put a small padlock through the latches Brendan |
6th Jan 2015 5:05pm |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 |
You could try one of these
http://www.ebay.co.uk/itm/Truck-Trailer-St...1226440023 Andy Defender Td5 XS90 |
6th Jan 2015 5:17pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Super - thanks for the info guys.
I don't plan on leaving the 110 out of sight for very long, usually when we're there we either park inside our courtyard or in a lorry park that has a guard... still, anything can go missing. |
6th Jan 2015 5:25pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
I dont use boxes, but...
I have 2 waterproof bags secured using rachets to U bolts in the roofrack. Click image to enlarge The system served well to me for almost 7 years. Easy to install, save weigth in the upper part (stability) and easy to storage when not in use. You can see it in some of my trip pictures Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
7th Jan 2015 2:18am |
Good weight saving idea, thanks for sharing that.
I do often wonder about overloading the rack; there is only so much you can put up there. |
7th Jan 2015 12:09pm |
On a different vehicle I used the Engel 40 Litre Fridge Transit Base
and then the corresponding feet fitted to a large metal transit case - worked very well for large bulky items that weren't too heavy. I also think the way motorcycle panniers/top boxes fit could be a way forward. Had an excellent set of Givi Monokey boxes that just clipped in and locked & just needed a key & press a release button to remove. Boxes were slightly streamlined and fully waterproof. |
7th Jan 2015 4:31pm |
