Home > Puma (Tdci) > 2.2 Clattering on cold start - any ideas?
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Hello all,
My 63 plate USW makes an awful, noisy clatter on cold start first thing in the morning.
It sounds like the big ends have gone for a couple of seconds, then it's fine.
On a warmish re-start it's fine too from key on.
The oil pressure light goes out straight away every time.
Is this one of those quirks that happens to all of them (as the dealer says) or has anyone had this problem and found a solution?
Thanks.
Simon. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #385511 6th Jan 2015 6:29pm
landy andy
I had big end noise, that was eventually worked out to be a new vcv, my noise was when hot, but then fitted new vcv and got noise (less) when cold until it was re calibrated into the fuel system
So my guess is either new vcv required and re calibrating, or just re calibrating your existing one.
BUT mine was on a 2.4 Tdci, so may be completely wrong.
Andy
Post #385514 6th Jan 2015 6:36pm
Macpaul
Thanks Andy but what's a vcv?! 2003 Td5 110 Hardtop
Post #385545 6th Jan 2015 7:47pm
landy andy
Variable control valve. It's a small electronic thing that bolts to top of the fuel pump. Easy to change but very very fiddly. But then computer kit needed for programming.
Andy
Post #385592 6th Jan 2015 8:50pm
Macpaul
Aha!
Thanks, I'll suggest it to the dealer. 2003 Td5 110 Hardtop
Post #385595 6th Jan 2015 8:53pm
landy andy
Post #385597 6th Jan 2015 8:55pm
Macpaul
That's great thank you. 2003 Td5 110 Hardtop
Post #385598 6th Jan 2015 9:02pm
Macpaul
Update - well the dealer's not interested.
'Its a normal sound for a Defender. Sir.'
Bloody well isnt.
Does it get worse if a variable control valve problem?
And if it is VCV, what's actually happening? 2003 Td5 110 Hardtop
Post #386584 8th Jan 2015 11:24pm
landy andy
I can only say by my experience, but I think it's overfueling causing diesel knock which is not good, as it can't control the amount of fuel correctly. I don't know if it will get worse as that will depend on if your VCV (if it is that) just needs re calibrating into the system, or if it is failing. If failing I think it will get worse, to a point that the knocking is considerable, and more constant.
A recalibration for someone who knows what they are doing, and has the kit is a very very very simple job, less than an half an hour, and would certainly assist with assessing the noise, and be my first stage.
Andy
Post #386625 9th Jan 2015 12:43am
