Home > In Car Electronics > Dual battery charging
orled
I have twin odyssey 1500's with IBS controller approx 18 months old. Notice main battery charge level drops to lower end 'orange zone' over 2 weeks when vehicle not used, auxiliary remains high. Is this normal or do I need to test battery / look for charge leak?
Post #385381 6th Jan 2015 7:21am
Probably alarm and/or tracker drawing power
Post #385382 6th Jan 2015 7:24am
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
The IBS controller/indicator probably draws a parasitic current from the battery, which is significant over a number of weeks.
I have a National Luna split charge system fitted, which I have incorporated an isolation switch into the indicator to stop the parasitic drain from the engine battery, when the engine is off.
Post #385407 6th Jan 2015 9:48am
