Home > Technical > Weight on roof
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Weight on roof
Hi,
I'm heading up to Broome shortly and I need a second spare tyre, which will go on the roof (god help me if I need to take it off). In addition to the tyre I intend to put a cargo box (recovery gear), 20L plastic jerry can (water) and some light bags (clothes) on roof as well. Taking into account that I already have a 2mtr long alloy luggage tray, I'm wondering whether this will be too much for the roof? I know the centre of gravity changes significantly, but I just don't want to break something due to weight - my instinct is that I should be fine with weight to spare, but some advice would be appreciated.
Also, how the hell does anyone ever get a spare tyre on/off the roof of a Defender without totally shattering their back? I don't want to look like 'Mr Bean Goes Outback'! Is there a special technique that I'm not aware of?
Cheers,
Rick. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #38511 19th Aug 2010 4:35am
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
Max load recomended by Land Rover (for areas outside of Europe) is 150 kg including the roof rack (only 75 kg for Europe).
KarlB
Post #38514 19th Aug 2010 4:51am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
the roof will take the weught as you see people with a 50kg roof tent then add two adults at 100+ kg each, i would say don't do it for on the move though just back from a trip with a group of people one guy in a disco 1 or 2 (slightly lower than a defender) had a not very over lowded roof rack on and made some side slopes look very risky when we just walk'd it with no problems, but thats just me.
Post #38524 19th Aug 2010 7:58am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Rick,
Regarding getting wheels off the roofrack...
Recently I had to carry 6 wheels home up on the roof rack and found the best way was to stand on the rack, pass a long strap though the wheel and lower it down under control over the back. I loaded them the same way which saved a lot of gruning Embarassed
worked for me ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #38547 19th Aug 2010 11:15am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I just got back from a trip from Romania, where I had to carry three large, heavy suitcases, boxes and 4 wheels w/ snow tyres (16'' wheels) for my wife's car.
I'm sure I was over the advised limit, and I could feel that it slightly affected the handling of the truck. I just took corners slowly and everything was OK. It wasn't grossly overloaded...
When it came to take the wheels off - I just went on top, undid the ratchet strap and threw them on the grass. Very Happy I didn't know that wheels/tyres would bounce like they did! Embarassed One took off down the street, had to run after it.
Post #38551 19th Aug 2010 11:32am
Martin
Site Admin
OT, but very smart 110 Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #38565 19th Aug 2010 3:22pm
AndrewS
Just got back from Morocco Whistle did I mention that before Whistle
Anyway on the Hannibal rack I had a Howling Moon roof tent, 4 waffle boards, Spare wheel, 2 Jerry cans, Awning and an AluBox full of er er crap. Got to some extreme angles in the dunes and all was fine. On the way home I removed everything that was not bolted to the rack (spare, waffles and jerry cans) and placed them inside the vehicle. The reason for this was the hotels on the way back had no secure parking. Removing these item made no noticeable difference to the vehicle performance or handling.
 130's have feeling's as well you know Smile
Post #38566 19th Aug 2010 3:46pm
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
you mean you could still only do 45mph up hill? Rolling with laughter
Post #38568 19th Aug 2010 3:51pm
AndrewS
46 actually 130's have feeling's as well you know Smile
Post #38574 19th Aug 2010 4:01pm
mse
KarlB
Just a note that isnt correct
UK/Europe spec is
The maximum roof load is 150 kg (330 lb).
When calculating the roof load, the weight
of the roof rack and any load carrier must
be included.
As for total weight - well do know someone who got the sides to collapse with the roof load! Mike
Post #38587 19th Aug 2010 4:51pm
rick
Thanks for the quick response guys.
Wyvern - thanks for the tip, that makes sense (I'm relieved), will make sure I have a long enough strap.
Eutek - thanks for the pics, clearly I have no weight issues with my proposed cargo.
Will post photos when I get back.
Cheers,
Rick. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
Post #38631 20th Aug 2010 4:47am
leeds
Re: Weight on roof
rick wrote:
Hi,
Rick.
A tyre weighs a lt less then a tyre/rim or wheel. So just take a spare tyre carcass or two? OK you will need tyre levers etc but a lot less weigh. OK a bit more work
Also a suitable size inner tube or wo. Yes inside of a tubeless tyre is rougher then a tubed tyre.
Main problem comes if you seriously buckle two rims!
Main problem I had with punctures in Oz was roofing screws in towns!
Water bladders are a better solution then jerry cans. Take up far less space when empty
Make sure you have a decent compressor onboard
HTH
Brendan
Post #38641 20th Aug 2010 8:09am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I think you might be quite surprised how much 150kg is. Also, i would think the 150kg limit is for "continuous" weight.
I recently did a trip though Lesotho with big tent, aluminium trunk full of heavy stuff, plastic trunk full of wood, 2 jerry cans (20lt water and 20lt diesel) as well as the weight of the roof rack (probably 25kg), and that's about a total of 130/140kg i reckon...
And then me (umm, a bit more than 100kg) often climbing up and getting stuff...
How the hell do you guys insert images??
here's 2 links:
http://www.ralton.co.za/images/lesotho/IMG_0268med.JPG
http://www.ralton.co.za/images/lesotho/IMG_0314med.JPG www.ralton.co.za
Post #38650 20th Aug 2010 10:00am
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Apologies in advance for a quick thread hijack Wink
Use a hosting site, I use Photobucket http://photobucket.com/
Upload your pictures, then cut and paste the pictures IMG Code (pops up when you place the cursor over the thumbnail) into your post here.
For instance the code
[***]https://s3-eu-west-2.amazonaws.com/i.hubnuts.uk/xpb/c6/c6b7d72ed59cc85e6bcd410489cd536a0a339df0cba2a920c063cfaff4c25d43.jpg[/IMG]
I've replaced the letters IMG with *** at the front so you can see the code not the picture; when complete looks like this:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #38703 20th Aug 2010 10:05pm
mse
here's 2 links:
host them in the gallery of this site Mike
Post #38711 20th Aug 2010 11:37pm
