![]() | Home > Maintenance & Modifications > Springs |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
id fit your winch and guard and then see what its like. The fronts are 175lbs/in and the rears are 225lb/in as standard. So yeah putting rear springs onto the front will increase the ride height for a given vehicle weight. Its not something id do myself. Id buy a spring set. EDIT: Just saw that you have a 110 in which case those spring rates are incorreect as they are for a 90.
unless someone has exactly the same setup as you, in terms of vehicle (spring) age, engine, tyres and accessories its hard to be sure exactly what you will end up with. Have a look here, there are lots of combinations possible. ![]() http://www.flatdoguk.com/search.asp?types=FD+SPRINGS My vehicle has winch bumper, winch, guard, tree sliders and sits slightly lower than id like at the front but not by much. the suspension is 175lbin front and 225lbin rear at standard height spring lengths. ![]() Click image to enlarge |
I have currently 225 lbs in the front and 285 in the rear. I might change the rear ones back to 225.
I found the 175 lbs/inch to weak when charging up a hill. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Bows Member Since: 07 May 2012 Location: Wales Posts: 521 ![]() ![]() ![]() |
Thanks for your replies, it is for a 90, 300tdi truck cab. I might do some experimenting. Just don't really want to end up with the front of the Landy looking like I've got a 2 inch lift
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
On my 300 Tdi I fitted standard rear springs to the front after I fitted a winch and steering guard etc as the front dropped by about and inch and a half. Sat nice and level afterwards
![]() Steve |
Thanks for your replies.
Thats what i'll do, fit rear springs in the front. Thanks |
