Home > Puma (Tdci) > Exact amount of Oil for change
CapeLandy
South Africa
The manuals says 7 liters, but I seem to have ordered american volume which was 7 bottles (US quarts) = 945 ml each.
I see also that from min to max on the dipstick is listed at 2 liters.
Will I get away with 6,6 litres to a decent level on the dipstick?
p.s the oil I have is hard to come by with costs to courier. Puma 110 - gone
Series III 1973 - going strong
Post #3842 14th Sep 2008 10:41am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Might be tight. I did a 5000km change - didn't change the oil filter - and used a very little less than 6L. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3843 14th Sep 2008 10:59am
CapeLandy
South Africa
The filter seems to take very little though.
Did you fill to the middle of the dipstick or max?
 Puma 110 - gone
Post #3844 14th Sep 2008 11:01am
mse
A relevant hijack of this thread (sorry)
Has the sump change changed the quantity required?
I only ask as it seems smaller? Mike
Post #3845 14th Sep 2008 11:06am
dm_td5
I filled to the top of the dipstick
Also I must admit the sump change does make me wonder if the oil quantity is less. I have the new sump on mine from the beginning. Just looking at the difference from the pictures posted though I suspect it might have only reduced the sump capacity by 100-200mL. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #3846 14th Sep 2008 12:52pm
Eduardo
CapeLandy
I just change the oil to my defender with the new sump (top of the dipstick) I bought 2 bottles of 5 lt each as far as I see I used around 1 1/2 or a little bit less, that means 7 liters app.
Regarding mse question, no, as dm_td5 said dont change too much. 100 - 200 ml should be a ggod figure.
Cheers! Eduardo
Post #3864 15th Sep 2008 2:08pm
CapeLandy
South Africa
Thanks ED
Mine runs at half mark on the dipstick as I got it from the dealer. (all my cars I have always kept half full)
This means I should only use 6 liters as the volume between empty and full on dipstick is listed as 2 liters.
I have 6,6 litres so in theory should be ok.
I will order one extra bottle for top ups though.
Thanks 4 help guys
James Puma 110 - gone
Post #3882 16th Sep 2008 6:35am
