![]() | Home > Maintenance & Modifications > Wheel Spacers |
I think the minimal thickness depends on your wheelstuds as you will tighten the spaces with your original studs and your wheel will be thightened on the studs build in the spacers.
I don't know the length off the studs but they will be close to 3 cm. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Thanks for the reply Roel
There is a bit of room though .... Here's a picture of some 30mm fitted to my friends truck - you can see you could take some width out ...... ![]() Click image to enlarge I have seen some 25mm ones for sale in the past - just not finding them now. There are thinner ones - but not hub centric, which I want. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
