Home > Technical > SQUEAKING STEERING WHEEL |
Resident mouse may be hungry? Is the wife/girlfriend/boyfriend/mistress sat in the passenger seat?
Are you travelling 'at speed' when this happens or almost stationary? Is it a squeaking or a sqealing? Is it coming from inside the cab or being generated outside? Is there any play in the steering? Have you checked fluid level? Have you looked for any witness/fouling marks on your steering column shroud? Bit scant on detail. Welcome to the fun factory by the way. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
31st Dec 2014 11:57am |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
I thought they all did that
Jeez just listen to me, only owned it for a few weeks and I've adapted to Land Rover build standards and tolerances. |
31st Dec 2014 1:23pm |
