Home > Puma (Tdci) > Whats this weird blue grease |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Sure it's grease and not something like blue Hylomar sealant?
15th Sep 2008 11:47am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
well if it was a sealant it has no sealing capabilities - isnt the measure seal a room temp flex at high temp Mike
15th Sep 2008 3:42pm |
Hylomar stays like a sticky goo. Without knowing roughly where it came from it's a guessing game.
15th Sep 2008 3:54pm |
And thats the problem i dont know Mike |
15th Sep 2008 4:23pm |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
have you hit something in the road ? not like a blue rabbitt ! i mean like something off a contractors truck or from some road workings ? is it joint stuff for pipes ? sorry dont know the technical terminology..........
Its feasable i supose ? well it is for me anyway. DEFENDER XS CSW 08 TONGA GREEN |
15th Sep 2008 5:24pm |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
Or a Smurf?? |
16th Sep 2008 12:51pm |
Damm !
Forgot about them pesky smurfs ! DEFENDER XS CSW 08 TONGA GREEN |
16th Sep 2008 3:50pm |
Sorry....... couldn't help myself Chalky!
I've had a look under my 110 and can't see any blue grease or sealer, most of the sealers that I can see is black. Have you checked the rubber boots on your steering joints/ball joints mse? One of them could have split or detached itself, and who knows what sort of grease they are filled with?? Tim |
16th Sep 2008 11:21pm |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 |
Smurfs.......I Like it
I would suspect it's an anarobic sealant, which seals when there is lack of air, but remains liquid in the presence of air, or even Blue hermetite, which is semi hard. I expect it's round the diff flange. Regards Steve |
17th Sep 2008 5:29am |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 |
my one how as bright yellow sealant on the gearbox after it was replaced
they don,t seem to need gaskets any more dan |
17th Sep 2008 1:01pm |
Makes sense - the excess (there was a lot) does wonders to lubricate the gate Mike
17th Sep 2008 4:04pm |
