Home > Maintenance & Modifications > Waeco heated seat kit
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Hi guys
Fitted all the new seat foam, covers and Waeco heated seat kits to the Defender seats today.
All went ok ish !
I now have the joy of trying to wire up the Waeco heated seats and the wiring diagram is CRAP !
Can anyone who has fitted the kit give me some advice about how to wire the kit up and where to run the cables ?
Also can the Land Rover heated seat switches be used instead if the Waeco one ? The Landy Rover ones look nicer ?
Thanks and hope someone can help Smile
Dunk
Post #382460 27th Dec 2014 9:06pm
Dunk,
Have you only got the switches?
I got the loom inc switches from Matt and the Waeco kit.
I'm intending to ditch the whole Waeco loom and use only the genuine loom and switches.
The Waeco switches are two way and genuine only one, I'm quite happy to live with just one heat setting though.
Post #382466 27th Dec 2014 9:29pm
Tank
Hi got the whole kit.
Just don't like the look of the Waeco switches , sad but true.
Also done a search of the forum and wiring seems ok, most in battery box, just where to connect the Orange wire ? The switched live Smile
Dunk
Post #382467 27th Dec 2014 9:33pm
Ask Matt @ FCX I think it's in the instructions of fitting.
Basically I'm intending to just use the Waeco heat pads and thats it, the rest the new loom.
So I'll only have one heat setting and the two way Waeco switches I won't use.
After all genuine heated seats are configured this way anyway.
Post #382474 27th Dec 2014 9:43pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I've been out doing mine today, I am just going to wire up using Waco switches to make sure it all works then swap for carling switches on my mud console. I found a switched live that was just lying about, no idea where it came from but seems to work and everything else still seems to be working Whistle Whistle
I have decided to leave the relay and fuses behind the mud console and run the cables to the seats through the gearbox tunnel in convoluted trunking and come up under the cubby box. I have lifted it by 3 inches so plenty of room for all the wiring.
It appears that the relay will always be powered up with the ignition switched on, so I am going to add a switch on the feed to the relay so that I need to switch it on rather than coming on and off every time I turn the ignition on and off, I'm assuming I am right in this assumption? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #382493 27th Dec 2014 10:22pm
I'd have thought the relay should engage only when turned on with a heat setting only not with the ignition.
After all, otherwise it may as well be directly connected to a switched ignition live anyway.
It seems to switch between the two settings somehow but on a 4 pole relay I cannot see how it does so but I'm not an expert.
It seems to be a normally open contact relay that's only engaged with power to one pin.
I.e. 86 trigger 85 earth
87 perm live 30 power out to device / item used.
It could be that the draw is actually switched with the current running though the actual switch?
After all there would be a max draw of 2.95A which isn't much.
Post #382509 27th Dec 2014 11:03pm
Greg L
Scotland 2000 Defender 90 Td5 SW Epsom Green
This helped me install mines last year
Post #382529 28th Dec 2014 2:06am
