![]() | Home > Tdi > Rear demist electrical conundrum 300tdi |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
Ok so getting a bit steamed up tonight I switched on the rear demist. When I got home and removed keys the dash warning light remained lit! I left it 10 mins and no change. Strangely when I clicked side lights on my drls lit too! They only come on when they sense voltage over curtain figure. Disconnected battery for now. Any clues why it would do this? My 109 thread
my youtube channel |
![]() Click image to enlarge cct for 300tdi Rear demist electrical |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
I had this on my 90, took the switch part and gave it a good clean up. Worked after that.
Lacy Member Since: 25 May 2011 Location: Birmingham(ish) Posts: 29 ![]() |
Yep, I would say either a dirty switch or sticking relay.
I've sorted it! There wasn't actually a problem lol. I rarely use it and hadn't realised how it worked. If I switch it on I have to switch it off! Now I can only switch it off if the key is in pos 2. I presumed it would switch off itself with key removed. so as long as key is turned it switches off no probs
![]() my youtube channel |
so if you forget to switch it off when you turn the ignition off it drains your battery?
I can't think why they did it non-ignition switched, and even it it was live all the time I can't think why you wouldn't be able to turn it off with the ignition off. It's like you've got an ignition-live switch controlling a permanent live latching relay. |
its a 300tdi with a td5 dash,so im guessing whoever did the conversion has wired it incorrectly! another thing for the to do list i guess
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Is there any advantage in having a TD5 dash? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
Looks very smart
mine had replacement bulkhead, and it came from a 2005 td5, dash was included so was fitted ![]() ![]() my youtube channel |
may just have to look into that then...... 2015 RRS Autobiography SDV6
