Home > Maintenance & Modifications > -14 to -20 have you topped up your antifreeze? |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
Our car had a 48K Mile Main Dealer service last spring, would new antifreeze have been put in it?
I notice it had an engine flush according to the invoice. |
26th Dec 2014 12:29pm |
Doctored an answer for you......
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Dec 2014 12:37pm |
LOL!
Someone reads my posts at Christmas - YAY! |
26th Dec 2014 12:44pm |
Andrew james Member Since: 02 Jan 2013 Location: Awliscombe Posts: 88 |
I am about to go to in Norway, so I am good for minus 50 .
Bring it on! |
26th Dec 2014 1:08pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Thanks for the reminder- I always check level but rarely consistency!
Should be ok but needs a top up so will top up with coolant Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
26th Dec 2014 1:12pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
This Pov.spec,ftw. 2006, 110,TD5. |
26th Dec 2014 2:32pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Just buy a cheapy tester and check it. Too much is just as bad as not enough
26th Dec 2014 4:03pm |
Don't think the usual testers can test oat anti-freeze,dunno?? Pov.spec,ftw. 2006, 110,TD5.
26th Dec 2014 4:08pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
What problems does too much anti freeze cause ? Checked mine and Mrs Sparts the other day hers was ok to about -32 mine was about -40 !!! 2005 Td5 90 XS
Steve |
26th Dec 2014 4:11pm |
Yep they do
26th Dec 2014 4:12pm |
Too much anti-freeze actually freezes and can cause overheating problems believe it or not. Your specs are fine |
26th Dec 2014 4:13pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Run Evans Waterless Coolant in my vehicles good to -40.
26th Dec 2014 4:39pm |
55% mix good for -50C
26th Dec 2014 5:22pm |
Had the bonnet up on her today and there is a Land Rover Label about genuine Land Rover Anti Freeze and Do Not Drain.
Is this something that would have been on it from the factory or does it sound like it's been applied at a service? |
27th Dec 2014 3:05pm |
