Home > Maintenance & Modifications > Battery dead but very warm- what do i do?
Page 4 of 6 <123456>
shaggydog
Quote:
Disconnect negative first....reconnect negative last = NO SPARK.
AHA!!
So, if I disconnect the negative with everything I can turn off turned off, and I get a spark does that say there is something making a circuit so something is wrong?
Would a tracker still plugged in cause such a spark? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #380975 22nd Dec 2014 2:29pm
munch90
you still get a spark if there is a load on the battery
the no spark comes from if you connect up neg last and your spanner touches the bodywork then you get no spark
if there is a current load on the battery when the leads are connected which ever way you will get a spark
Post #380977 22nd Dec 2014 2:31pm
munch90
clock , alarm , tracker will all draw a bit
really you need to get down to maplins and buy a meter
Post #380980 22nd Dec 2014 2:35pm
shaggydog
Multimeter purchased Thumbs Up
http://www.screwfix.com/p/lap-mas830b-digi...600v/75337 not bad I thought.
So.
How do I use it and what am I checking?
Again massive massive thank you's to everyone who has helped so far Bow down Bow down Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #380988 22nd Dec 2014 3:00pm
Venomator
Good job on the Multi-Meter Shaggy... Thumbs Up
It would have been my choice if they did it in Green... Mr. Green
Just waiting for mine to check out the quality and functionality, if it turns out to be good value, and as well built as some of the reviews suggest, I may even consider a slightly more expensive model, in Green of course... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #380994 22nd Dec 2014 3:13pm
shaggydog
Thank You Venomator Very Happy
Like you it was a done deal but because it was blue
Anyway had a quick go and hopefully I have found some meaningful things.
Old battery after being on charge since 11:30 is showing 12.57 with the number dropping off my a tenth of a milivolt every 5 seconds (is that normal?) with the charged disconnected
When I plugged it into the charger again this went to 12.78 and stayed steady.
Outside in the defender new battery with everything off I can turn off (only things drawing are tracker and clock and radio) was measuring 12.64 V
What does this mean and have I tested the right things? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #380999 22nd Dec 2014 3:33pm
Rickydodah
You'd be better connecting the multimeter, set on DC amps between the negative post of the battery and the earth lead. This will indicate what the AMP draw is from the battery. If you've just got the clock and the like running then your looking for 0.5 amp max I'd say, that's around a 6watt consumption about the same as a sidelight. Thumbs Up I started with nothing and still have most of it left!
Post #381005 22nd Dec 2014 4:00pm
shaggydog
Will go and give it a go Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381009 22nd Dec 2014 4:06pm
munch90
don't try and hurry it , leave it on a low charge for a long time , trying to hurry it along you will get a voltage but no guts to it
Post #381012 22nd Dec 2014 4:16pm
shaggydog
Did it but not sure I did it right because nothing much really happened Big Cry
I have never used one of these before so this is what I did.
Unplugged negative lead.
Set dial to 2m on A with straight line above and 3 dots below
Put red lead to battery - and black lead to the loose cable.
nothing happened. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381014 22nd Dec 2014 4:18pm
munch90
always start with highest amp setting just in case
cant get a big enough pic to see dial and advise
middle hole for black lead , red lead 10adc above lap word
Post #381019 22nd Dec 2014 4:25pm
Venomator
nothing happened.
10A seems to be the highest setting on your dial?
As Munch says, start there and see what you get, although I would go straight to the Earth connector, rather than try and use the loose lead... Thumbs Up
 Rog... Mr. Green
The GREEN One...
Post #381020 22nd Dec 2014 4:28pm
shaggydog
Pic of my Multimeter.
I had it set to 2m at 3 o'clock
Was my positioning of the wires correct (red on battery black on cable) ?
Again thank you all for your input hopefully others are reading and learning along too Bow down Bow down Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #381023 22nd Dec 2014 4:31pm
munch90
10a dial setting at about 5 o'clock on meter dial
DONT forget you need to disconnect the battery earth lead , then use the meter leads to complete the circuit again
Post #381024 22nd Dec 2014 4:33pm
Venomator
And you'll probably need to plug the Black lead into the left hand socket... Thumbs Up
EDIT - and yes, you were using the cables the conventional way round... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #381025 22nd Dec 2014 4:34pm
