Home > Puma (Tdci) > Defender Tdci 48spline steering wheel |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Give it a go and like you said you can always sell it on.
I think the best looking wheel is on the JE webs site. Have a look http://www.jeengineering.co.uk/landrovers/...or-styling |
20th Dec 2014 9:58pm |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
It does fit, a friend of mine fitted one to his TD5 "air bag" wheel. Can't remember how good the colour match was unfortunately! Tom
@tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
20th Dec 2014 10:24pm |
dazzx10r Member Since: 26 Nov 2014 Location: Rotherham Posts: 17 |
how old is your Defender? does it have stability control? if so then you can't just go fitting any old steering wheel as the current one will have steering angle sensors fitted to it. There are a couple of after market steering boss's out there now with this fitted. http://www.ebay.co.uk/itm/361075546069?_tr...EBIDX%3AIT
21st Dec 2014 8:33am |
Knot-yet Member Since: 21 Nov 2013 Location: N. Lincs Posts: 39 |
Thanks tdci guy, nice to have it confirmed that the older type flatter pad should fit.
Who knows when it'll show up in the post though! None of the bits of trim in a defender match perfectly in terms of colour and texture anyway so reckon even if it's not perfect I'll live with it. Hi, dazzx10r. It's on a 64 plate and so does have ABS, TC and stability control even though it's a base spec hardtop. I had heard that too. I aren't sure if the flatter 300tdi style wheel will be compatible? Which is why I went looking for an easy alternative as twenty quid for a flatter foam/rubber pad from fleabag was cheaper. I did actually like the look of the star tech wheel on the link to JE engineering but at 400 queen quids its a bit expensive for me. |
22nd Dec 2014 7:55pm |
