Home > Maintenance & Modifications > Side Steps - Ordered
CatherineF
I've found a pair of XS Steps locally that have just come off a 2014 Defender, so have taken the plunge and am going to collect them tomorrow.
I know someone suggested I spray inside them to rust proof them, would you go with Waxoyl or Dinatrol? When the step arrived from LR Direct it did appear to have a small hole in it, which a tube could be fed into.
Post #380465 20th Dec 2014 2:35pm
bob neville
Hi Catherine
I suggested rust proofing the insides of the steps in a PM to you Thumbs Up
My weapon of choice is Dinitrol. Tried Waxoyl and I just can't get on with it. You are in the motor trade so you may also be able to get Kent cavity wax. My local body shop sprayed some new doors for my TD5 and gave me a can of Kent cavity wax to treat the inside of the doors when I fitted them and it did flow well and had very good adhesion once on the metalwork.
2013 Defender 90 CSW - sold
Post #380487 20th Dec 2014 5:13pm
CatherineF
Hi Bob, ah yes I remember your Avatar now Very Happy
Dinitol do a 500ml can of cavity wax with a spray tube so was thinking of getting that. I'll have a look though at the other product you've suggested.
Post #380488 20th Dec 2014 5:16pm
mk1collector
Bilt hamber dynax ub
Post #380514 20th Dec 2014 7:07pm
I'm sure Bob already mentioned it it Dinitrol do a long draw straw for internals with a 360 degree spray.
You push it in as far as it'll go, then draw it back spraying from the can to give an even coat inside.
Post #380532 20th Dec 2014 8:33pm
CatherineF
Been to collect them this morning and really pleased.
Basically the chap's father runs a well known LR Specialist local to me and they both participate in the Defender Challenge.
Post #380675 21st Dec 2014 12:26pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
The picture below shows what will happen to your side steps if you don't rust proof them internally, I removed mine last year to have them re powder coated and this what I found !
 2005 Td5 90 XS
Steve
Post #380754 21st Dec 2014 6:12pm
CatherineF
Jeezzz, how old were those steps?
I've ordered 2 cans of dinitrol to use on them.
Post #380757 21st Dec 2014 6:22pm
Lou Sparts
I assume they were fitted when new in 2005 I removed them last year so eight years old ! 2005 Td5 90 XS
Steve
Post #380760 21st Dec 2014 6:24pm
CatherineF
Ok, so a final question guys, I have the Dinitrol and the long straw for spraying into cavities.
A couple of questions.
1) Would you spray once they are installed on the car or before?
2) How do I know when I've sprayed enough inside and got good coverage?
Post #382264 27th Dec 2014 10:49am
Remove end caps before fitting, then fit and then Dinitrol.
That's what I'd do anyway, if you do it before it might be more messy thnk need be.
The mount is just judgement.
Post #382265 27th Dec 2014 10:57am
CatherineF
Right well I've Dinatrol'd them, what a messy job it was too.
Post #382689 28th Dec 2014 4:29pm
