Home > Puma (Tdci) > Puma 2.2 remapping |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6587 |
The Defender maps are different to the Transit, so his Transit remap won't be right for your Defender.
If you want/have to remap, consider the replacement cost of the engine should something go wrong because you tried to save £100 or so 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Dec 2014 2:25pm |
dazzx10r Member Since: 26 Nov 2014 Location: Rotherham Posts: 17 |
what is different about them? why would a transit map kill the defender engine?
18th Dec 2014 2:27pm |
Well, they are totally different vehicles with totally different drivetrains and customer requirements for a start. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
18th Dec 2014 2:29pm |
And I'm not saying it WILL kill the engine, but a Transit map is not designed for a Defender and vice versa.
Any number of analogies spring to mind but I'm not that mean 1988 90 Td5 NAS soft top 2015 D90 XS SW |
18th Dec 2014 2:31pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
Jah boet, not worth saving 100 quids on a remap.
Rather get a proper one that's tailor-made for the Defender. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
18th Dec 2014 2:36pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8579 |
There is a very good reason why Pete at BAS, Gary at Alive and Ian at IRB have got a very good reputation for remapping Defenders.
They are simply good at what they do! YES there is lots of other people who will 'remap' your Defender for you, yes they will probably be cheaper in the first instance. However when you have to go to one of the above to sort out the bodge job that someone who has done a generic one size fits all remap then any savings has gone right out of the window. I believe it was Pete at BAS who first cracked the Defender 2.2, he has a rolling road to test his products on. Believe Alive now has a rolling road, sorry I do not know if IRB has its own rolling road. A rolling road is a considerable investment to ensure that they have got the remaps correct. Since you are at Rotherham none of the above are a long way away from you as well. Why risk the engine of a £30,000 vehicle to save £100? Personally I would not let anyone but the above 3 loose on remapping my Defenders. Brendan |
18th Dec 2014 5:45pm |
I do live in the South and Pete Bell provided mine hassle free, it did make me chuckle the lengths people will go to to perhaps save a little money.... You've a vehicle that is only a year old cost ballpark £30k plus and wish to save perhaps a ton by remapping to a totally different vehicle specification? Why not ask Gary or Pete what they think of your 'plan!' You've stopped taking your medication haven't you? No offence meant or implied but your idea is 'barking mad!' If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Dec 2014 5:48pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Personally I would tend to agree with Brandan and K9f but not wholeley. There are many Land Rover specialists that have spent tens of thousands of pounds and hundreds of hours developing tunes for all models of Land Rover including the defender, most of which have rolling roads. (I.e Gary at alive, Pete Bell, IRB, Monster Tuning, JE Engineering etc) I agree Gary, Ian and Pete are the top 3 but plenty of companies are capable of doing brilliant work with regards to tuning the defender. I have used Gary, je engineering and monster tuning for tunes on customers vehicles numerous times and have never had an issue with any of them. People tend to stick with what they know and are totally against accepting that someone else may be perfectly capable of doing a job to the same quality but doesn't have the same name.
The long and short of it is that 9/10 people wouldn't be able to tell the difference between a car mapped by any of the above. Just my 2p worth |
18th Dec 2014 9:04pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
speak to pete bell iirc he will load the map onto a new ECU and send to you complete plug and play and you have a spare ecu if you ever want to change it back for mot etc
give him a call!! 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
18th Dec 2014 9:12pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
It's amazing nowadays when an engine not only appears in 1 manufacturers range of cars, but a wide range of manufacturers cars.
The 1.6 HDI Engine's found in Peugeot/Citroen's appear in Ford's Volvo's and Mini's. The 1.6 THP Peugeot/Citroen Prince engine was in the last generation Mini Cooper S. |
18th Dec 2014 9:41pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Nowadays...
Remember the k-series? Just one example of the past. |
18th Dec 2014 10:06pm |
Double....
18th Dec 2014 10:11pm |
