Home > Maintenance & Modifications > LED headlights
Page 3 of 3 <123
mpm
United Kingdom 2013 Defender 110 Puma 2.2 USW Stornoway Grey
K9f,
Thank u excellent pic. Are those Noldens Thumbs Upm
Post #379753 17th Dec 2014 8:28pm
mpm
Brendan,
IP ratings on the lamp are all well & good, but, if moisture creeps in around the spade connectors the resultant voltage fluctuations could be sufficient to take out the led driver resulting in lamp failure. This is the Achilles heel of led lamps I think.
Post #379782 17th Dec 2014 9:37pm
leeds
Mpm, that may be the case with cheaper LED's manufacturers.
Nolden headlights are tested to
The test specifies a spray nozzle that is fed with 80 °C water at 8–10 MPa (80–100 bar) and a flow rate of 14–16 L/min. The nozzle is held 10–15 cm from the tested device at angles of 0°, 30°, 60° and 90° for 30 seconds each. The test device sits on a turntable that rotates once every 12 seconds (5 rpm).
Or 80 C water, minimum pressure of 1160 psi from a maximum distance of 6" is a pretty demanding test I would say
To date I have not heard of one failure of Nolden lights. We supply a lot of Nolden DRL's as well as 7" headlights and have not had to replace one unit yet for any reason!
Brendan
Post #379789 17th Dec 2014 10:01pm
K9F
mpm wrote:
K9f, Thank u excellent pic. Are those Noldens Thumbs Upm
Welcome! Thumbs Up Noldens.....unfortunately not but hopefully a resolution is in the pipeline. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #379822 17th Dec 2014 11:17pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
They are also subjected to a 480 hour salt spray test. Working as a design engineer whos parts are used by many of the major car companies, I know this can be a tough test on any metal parts.
I'm not sure of the exact detail of their test, but typically the parts are sprayed with a salt spray for a number of minutes, baked for an hour and the cycle is repeated for 480 hours. http://defender90xs.blogspot.co.uk/
Post #379840 18th Dec 2014 7:03am
mark_d
Looking at some customer specs, the Japanese OEMs consider 96 hours to be 2x life testing i.e. 20 years.
The harshest spec I've seen in 960 hours which is made up of 40 cycles of:
6 hours spraying 5% salt solution at 30 degrees
1 hour at 60 degrees to dry it
16 hours at 50 degrees and 95% relative humidity
Finally 1 hour ramping back down to 30 degrees to repeat. http://defender90xs.blogspot.co.uk/
Post #379991 18th Dec 2014 3:22pm
Page 3 of 3 <123
