Home > Maintenance & Modifications > Shadow Lightbeam |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
I was thinking of fitting a Shadow Lightbeam (link below) on my Defender.
Any body fitted one and, if you have, what do you think ? http://www.firstfour.co.uk/defender/shadow...582171.php If I go ahead with this I will be fitting Lightforce 140's. Thanks Bob |
12th Aug 2010 3:39pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5047 |
Check they fit - they dont on some models especially air con ones ISTR.
They dont look as good in real life as in the photos i think Mike |
12th Aug 2010 8:47pm |
Thanks for the replies.
I had a good look at the fitting instructions they sent me and the area behind the front grill where they fit and I reckon there is no way to fit the bar without removing the rads I think I will get a couple of brackets made up to fit on the bumper bolt points, it will probably be far less hassle and a lot cheaper ! Bob |
13th Aug 2010 7:19am |
why not get a light pod that fits onto the bonnet ? or have a look at the 60th editions that have spot lights built into the cluster? |
15th Aug 2010 6:17am |
