![]() | Home > Maintenance & Modifications > Anyone in Hants or Surrey handy with a welder....small job |
Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750 ![]() ![]() |
Chaps ive a small leak at the top end of my rear diff casing.im based in Aldershot ..can travel with the truck after someone whom might be able to pop a spot of welding over the hole for me..currently in Peterborough but back on Monday ...
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
To be honest, the diff casing is so thin you run the risk of actually making it worse! [Unless you are a pro welder]
You'd be better off cleaning/degreasing the area and repairing it with a compound. JB Weld is great for that sort of thing ![]() |
dave thanks very much for the advice.
Terry |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
If you're passing south wales at all I'm sure I could help you out. I work for hobnobs
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
You could use something like this I did a temporary repair on a sump with it and it was still there 4 years later when I changed my car.
http://www.amazon.co.uk/J-B-Steel-Reinforc...B000786GLM 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Cheers guys thank you all for your help ,input
![]() Terry |
