![]() | Home > Puma (Tdci) > Knocking noise on right turns? |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Yikes! Just read Naks post "Brand New Puma Pulling To The Left" - hope I'm not about to go on a similar path...(albeit one drifting to the left
![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
check out my thread "any ideas". i have a similar issue. mines going to the dealer on monday, but i have checked absolutely everything apart from engine mounts. my noise is the same, sounds like offside suspension front, but all bushes are ok, springs seated correctly etc etc etc. be good if you update what it is assuming they can find it.
Mmmm....not liking the sound of this too much. The car drives well otherwise, but the pull to the left is becoming more noticeable. And of course, once you know it's there you feel it all the time...
![]() It will be very interesting to see how this one develops then. I get on well with my dealer, this is the 4th car I've bought from them, so this could be an interesting test of that relationship... ![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
Just read your thread - thanks Mike. Useful info which I will pass to the dealer just in case it helps Simon
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
did this ever go any further / get resolved?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Left ball joint perhaps.
Diff-lock stuck in?
