Home > In Car Electronics > Focal, Hertz or Infinity
Page 2 of 3 <123>
Post #378314 12th Dec 2014 7:41am
Post #378346 12th Dec 2014 10:01am
If the 2 DIN dashes are in two halves what fixes them both together? Or are they just held in place from the rear?
I too don't mindthe look of them or the extra panel but I dont lie the circular hole section.
If you cut it off I don't expect that edge sits flush with the dash?
Post #378358 12th Dec 2014 11:22am
The upper clock / vent section has its own clips holding it in place as does the new double DIN panel, although the two touch (presuming you've done a good job cutting the top section) they aren't physically fixed together.
We've cut the bottom off switch panels but they have to be glassfibered and then painted to make a nice job of it, which is why we developed the cubby with switch positions - we are also just finishing off a 4 position cubby to accomodate the DSC control that takes up the last blank in 2015 models
Post #378359 12th Dec 2014 11:26am
What have you been cutting the two apart with?
I was thinking much along those lines that the edge on the switch panel wouldn't be flush, fibreglass is probably tricky on an area so small as that but done properly would look flawless.
I suppose the plug extensions required are using new plugs that are extended?
Pity there isn't an add on loom where you can plug in male one end and fe serge other where you simply effectively add in a section using proper plugs without chopping any off.
Only downside is the bulk of the plugs themselves.
Post #378363 12th Dec 2014 11:38am
It is possible to move the switches over to the new switch panel WITHOUT extending the cables.
If you are moving the switches into an FCX cubby then we can supply premade looms that do not require cutting of anything (much like our heated seat loom)
The existing panel can be cut with a hot stanley blade
Post #378366 12th Dec 2014 11:43am
Didn't know that. Thumbs Up I have my own cubby custom built for my sub so that's a no go as there isn't room. Rolling with laughter
Post #378369 12th Dec 2014 12:03pm
CatherineF
I can't believe that there no longer appears to be any car audio shops!
I've just googled and there is pretty much nothing and Halfords range looks pants!
Post #378597 13th Dec 2014 10:27am
What are you looking for? Fitting or a selection to look at?
Post #378600 13th Dec 2014 10:35am
CatherineF
Just to go and look Steve and possibly even buy.
Can you suggest anywhere?
Post #378602 13th Dec 2014 10:37am
Only places I can think of is in Bristol, but even then they really are rubbish.
You can make a better choice online IMO.
I've used In Car Music, Car Audio Direct, and Just Kenwood many times.
Post #378603 13th Dec 2014 10:39am
CatherineF
Cool will take a look at them.
Post #378604 13th Dec 2014 10:55am
I got my HU years ago from Just Kenwood and speakers.
Sub and Amp etc from In Car Music.
Wiring and fuses etc from CAD.
Fitted it all myself, something I rather enjoy too. Mr. Green
If you need any fitting doing or anything is a bit complicated I'd be quite happy to do it for you if need be.
Professional car audio shops. ( As the call themselves Rolling Eyes ) usually charge princely Suns for what I call highly basic bash it in a job done style approach.
Usually using cheap kit for max profit.
Post #378609 13th Dec 2014 11:10am
Likeomg
speak to urban truck, they offer 3 stages of audio upgrade which is tailored to the defender...
Post #378641 13th Dec 2014 1:22pm
Albion
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
another 2 DIN setup on my 90 XS SW Puma
hi all..just had this done by a company in Hertfordshire...the head unit is a Pioneer AVIC F60DAB with Apple Car Play and it has a reversing camera feed to a camera mounted on the rear. I've also added switches on the subsidiary panel for heated wing mirrors which they also installed and an existing rear work light.
Post #378682 13th Dec 2014 4:11pm
Page 2 of 3 <123>
