![]() | Home > Puma (Tdci) > Service cost |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
Hi All
First service due on my 59plate puma, any body know how much i should be paying?? Regards. Yanto |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
First service or 12,000 mile service in 2009 cost me 213 which included an oil change at a maindealer. Prices seem to vary.
Second or 24,000 mile service ran to 350 at the same dealer.Air and fuel filters were the expensive items on that one. You should get an invoice, a Land Rover visual healthcheck sheet with appropriate checks ticked and items needing attention (like a small oil leak from the rear diff in my case. This will be attented to under warranty when the parts are ordered in).Also a Land Rover maintenance checksheet with all work sceduled to be carried out marked off on it. Armed with those three things you have comprehensive paperwork stating everything that should be done has been done. Don't forget to get stuck into the tea and biscuits while you are there. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5069 ![]() ![]() ![]() |
I dont think you will get a UK service at a main dealer into the 200 mark - I rang every dealer in the midlands and managed to get about 110 off the price, but i wouldnt expect much more.
Prices do vary across the UK - but i would suggest around the 300 mark is about as low as you see your first service. Mike |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
When I was looking a few months ago the cheapest local main dealer was Likes in Brecon. I was after a 2 year service, but their twelve month one was 285 at the time. Peter
2008 SWB Truck Cab 1952 80" Soft top |
Doesn't anybody use the search facility before posting? ![]() Treat every day as if it is your last....one day you will be right!! |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 310 ![]() ![]() |
At least it provides us the opportunity to increase our post count! i paid 225 inc vat with a main dealer after pointing out the cost of an independent 1st service. Then they found a couple of oil weeps which was fixed under warranty, via another dealer as the other dealer only offered a Mini Countryman as a courtesy car.
As an aside the 110 Puma seems to use little engine oil. I've just done 800 miles last weekend, and 6k since the 12k service and I've put about a half a pint in since then. ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
my first service was 270 Cheers
Same for me further south about a ton plus off the cost by playing main dealership against independant! This subject has been 'done to death!' http://www.defender2.net/forum/topic3587.h...vice+costs http://www.defender2.net/forum/topic3262.h...vice+costs http://www.defender2.net/forum/topic3038.h...vice+costs http://www.defender2.net/forum/topic2711.h...vice+costs Then I got bored....results from first six pages of 12 possibilities..... ![]() Treat every day as if it is your last....one day you will be right!! |
Its like the TV you dont have to turn it on ![]() ![]() Anyway why quote me i didnt ask the question ![]() |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
Lucky B@sterds!
My first service was over 1000 Francs!!! ( around 500 's) I think I need to drive to where they drive on the other side of the road to get my services done... 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
I went for a 25,000km check in my dealers shop and paid almost USD156. what they done was change oil tightening of bolts and carwash! I even supplied my own oil!
Last time i looked some dealers were charging 100 +vat per hour labour! for defenders and freelanders Mike
Mse,
I quoted you merely to agree with your point of getting about 100 off through negotiation (if you read your quote and my sentence it still makes sense to me???). No other reason! Apologies my post obviously wasn't clear enough and/or you misread it! The ensuing sentence about this subject having been done to death was not directed at you in particular and it has been "Done to death that is!" ![]() Treat every day as if it is your last....one day you will be right!! |
Ahhh - i miss read - ill stop being so sensitive ![]() ![]() ![]() |
