![]() | Home > Td5 > Transfer case - difflock light switch |
IIRC they're adjustable, they screw in and out to find the point when the light works like the reverse switch
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
As aobve, but they do fail. When I fitted a replacement (low mileage ex-written-off vehicle) t-box on mine last year, the switch didn't work on the new box. I fitted the switch off the old box, which had been working fine, and that didn't work either! A new switch sorted the problem.
If you unscrew the switch you can test it with a meter to see if it's working, just press the ball on the end and you should see the switch close, release the ball and it should open. On later vehicles the switch isn't adjustable, you just screw it all the way in. Also on later vehicles the connector is different to earlier ones, other the switch would be identical. You can of course cut and splice to combine old and new parts if necessary. |
